Tie rod question
Discussion in 'The Garage' started by opfor2, Nov 1, 2002.
  1. opfor2
    opfor2 1/2 ton status
    Oct 28, 2002
    375
    Ventura County, CA
    How do you tell if your tie rods need to be replaced ?
    I have a stock 1990 K5 Blazer 4x4.
    Dan..
  2. ColAdo82K5
    ColAdo82K5 1/2 ton status
    Feb 18, 2000
    789
    MO
    Dan,
    Welcome to the CK5 family. To see about those tie rods are fairly simple. Just grab them and see if you get any play in them. If you can get them to move around a little too much imagine what a 5000+ lbs truck can do. Check out those rubber boots on them....if they still exist. Make sure they are sealed well and holding in grease. If you take a peek in there and everythign is dry..it might mean that they have been runnign with out grease for a long time. =no good. To make sure they are bad go to any Dobbs Auto place...they will fail any part even if it's brand new.
    You can replace them your self and do your own alignment right in your driveway. This topic was just covered...do a serach of the last few days on how to align a straight axle vehicle.
    Blake
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Look at each tie rod end while someone moves the steering wheel from side to side. If the body of a tie rod end starts to move before the stud end of it does, then it's worn. Both parts of it should move in unison. /forums/images/graemlins/cool.gif
  4. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    If you end up replacing your TREs I highly recommend you buy Moog replacements.....
    While you're under the truck make sure you check out the ends on your draglink. The same issues apply to them.
