Tie rod removal help.
Discussion in 'The Garage' started by 5trucks, Mar 15, 2007.
  1. 5trucks
    5trucks 1/2 ton status
    Aug 12, 2005
    169
    Yuma Az.
    I did my x-over and my tie rod mounts from the top of the knuckle. The clearence is very minimal and will not allow me to remove the tie rod. Do i need to remove the knuckle or is there another trick to doing this? I need to weld my hydro assist brackets on and i want them to weld nice so i want complete control of the tie rod. Thanks!
  2. ccatlett1984
    ccatlett1984 1/2 ton status
    May 1, 2005
    161
    michigan
    post a pic, so we can see what you are talking about.
  3. 5trucks
    Aug 12, 2005
    169
    Yuma Az.
    The best i can do right now. Hope the visual helps. Thanks!
  4. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    That should be plenty of room. the TRE is tapered, so as it comes up, pull it forward.
  5. Jason4x4
    Jason4x4 1/2 ton status
    Nov 5, 2006
    4,505
    6
    Chandler, AZ
    have you actuaaly tried to remove it, or is it just because it doesn't look like it will come out. Kinda looks to me that it might be able to be maneuvered out.
  6. YZEATER
    YZEATER 1/2 ton status
    Jan 21, 2005
    2,358
    TARENTUM, PA
    let the axle droop down by supporting the weight of the frame. you'll have enough cleance then.
  7. W7NB
    W7NB 1/2 ton status
    Nov 9, 2006
    716
    Springtucky, OR
    Just take the sleve off -remove the bolts and nock the clamps back with a hammer - probably will need to pry it apart and rotate the tie rod end forward. Should be easy to get off the truck at that point.
  8. Leper
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    That will not change how big the knuckle is.
  9. YZEATER
    Jan 21, 2005
    2,358
    TARENTUM, PA
    the springs will arch and create room between the rod and the spring pack. think about it looking from the side.
  10. 5trucks
    Aug 12, 2005
    169
    Yuma Az.
    Thanks all. I will attempt tomorrow.
  11. Masiony
    Masiony 1/2 ton status
    Sep 2, 2005
    729
    Springfield, OR
    are you going to use a factory tie rod for hydro assist? it may be wiser to put something less like bailing wire on there for something as strong as a hydraulic ram. just my .02
  12. 5trucks
    Aug 12, 2005
    169
    Yuma Az.
    All i have for now. I am gonna make something up outta 1 1/2" .250 wall when i get the funds but for now, i think it'll hold. Ran hydro assist on my 79 scout II on the factory tie rod with the same ram and never had a prob playin @ the hammers. Swithched to a d60 and used the factory one there also. Again, no issues. I hear ya though. I take and welcome all advice. Thanks!
    Damn, i was a fat bastard.:eek1:
