Tie rod suggestions
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BillyBob, Apr 18, 2004.
  1. BillyBob
    BillyBob 1/2 ton status
    Feb 23, 2000
    557
    Dumont, NJ
    From what I understand, RockStomper has stopped making the Rock rods. I REALLY need a tie rod bad, cuz the one I ghettoed up to my D44 isn't holding well after 2 years of abuse. Does anyone know where I can go to get a thicker than stock rod for my 3/4 ton '74 D44?
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
  3. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Missouri Offroad Outfitters
    Offroad Design
    Sky Manufacturing
    Harley
  4. mr_fujisawa
    mr_fujisawa 1/2 ton status
    Sep 1, 2003
    288
    SF CA
    or you can do like i did and buy the normal tie rod ends, then have them sleeved and the sleeve welded on by somebody and you have one think motha' f'n tie rod.
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Sky Manufacturing /forums/images/graemlins/thumb.gif
    I would normally say so as well, but theirs are only available in 1 1/4" .250" wall so I'm going to get mine from someone else.
  6. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    This is true, but I asked sky if he'd be willing to make me one out of 1.5" and he did. Now I don't know if that was a special one time deal, but you might ask if you call.
  7. BillyBob
    Feb 23, 2000
    557
    Dumont, NJ
    I dunno if I can do that. My knuckles are 1st design (going to get crossover /forums/images/graemlins/cool.gif), and accept only those offset rod ends.
    I've been using the tie rod off of my 84's 10 bolt, but it's touching the springs, and the ends aren't fitting the tapers properly, so it's loose. I'll probably bug Steve at ORD, cuz I've done buisness with him before.
  8. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    shakerbuilt.com has them. He claims to have a 1.5" .50 wall version available.
  9. ColAdo82K5
    ColAdo82K5 1/2 ton status
    Feb 18, 2000
    789
    MO
    Hey.
    I have early knuckles on my front 44, with a stock style 82 tierod and there is clearance. How much lift do you have ? I am using 6inch springs and a 2.5 shim under the front pack. The steering stabilizer fits too.
    The taper between all of the knuckles are the same. CHRIS T on the board here just used a 80 style rod on stock 72 knuckles and all the tapers should be the same. His old rod was one like you showed pictures of.
    Blake
  10. Chris_T
    Chris_T 1/2 ton status
    Mar 17, 2001
    718
    Saskatoon, SK
    Like Blake said I was able to use the later style tie rod on my '72 Dana 44, but I have 6" springs with an integrated shim which gives you a little more room to wiggle it in there.
  11. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I asked when I ordered my crossover and they told me that's the only tube they had around the shop. Kinda disappointed me. /forums/images/graemlins/thinking.gif
  12. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    /forums/images/graemlins/thinking.gif /forums/images/graemlins/thinking.gif /forums/images/graemlins/thinking.gif Cause when i got mine about 6 - 8 months ago, I ask that similar question and I was able to get the bigger tubing rod. Maybe he's changed since then /forums/images/graemlins/thinking.gif
  13. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Not sure. All I know is that I wanted one that was much thicker wall, and he didn't have the tube available. I told Brian, "This isn't a jeep or a toyota, this is a fullsize, and that's not heavy enough." Unfortunately he said that was all they had, and I told him to skip the tie rod, and I just ordered my crossover, which I'm VERY pleased with for all of you to know. I would have ordered a tie rod at the same time, but they didn't have one any heavier than 1 1/4" .250". MOO and ORD both do though, so I'll probably order from them.
  14. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    I told him to put in a zero rate and be done with it, but he does not want to. /forums/images/graemlins/tongue.gif
  15. Eric M.
    Eric M. 1/2 ton status
    Dec 10, 2001
    2,118
    Oakland, CA
    Hey Sean,
    Is that tie rod in backwards? I'm looking at the hole for the steering stabilizer. Does it have to go in that way with the mods you did to it or could it go in so you could still use a stabilizer?
    Eric M.
  16. mr_fujisawa
    Sep 1, 2003
    288
    SF CA
    too funny that you ask that!
    it is in backwards (thanks to grendel) and i need to switch it back so i can put a steering stabalizer on there. i get the death wobbles somethin' fierce.
    /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif
    *disclaimer* death wobble is not actually funny. it sucks.
  17. Eric M.
    Dec 10, 2001
    2,118
    Oakland, CA
    Yeah, I don't know what those guys who don't run steering stabilizers do when they actually get on the streets. There's a reason these axles were designed with steering stabilizers. I bolted up my rebuild D60 to my Suburban at about midnight last year. The good'ol folks at 4WPW sold me the wrong steering stabilizer. I figured what the hell and took it out for a test drive. I got the wobbles so bad flying down Junipero Serra Blvd., I was about to park the damn thing and walk home! You really need those stabilizers.
    And you're right, DW aren't anything to laugh about. They scare me.
    Eric M.
