Tie rod
Discussion in 'The Garage' started by 4X4HIGH, Nov 13, 2005.
  1. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    For those of you running an ORD Tie rod what size rod did you go with? Also will DLE's work in place of the stock TRE's, IE: same taper? I am just wondering so i don't have as many different parts on my rig. It would be nice to have the same ends on both my tie rod and crossover draglink.
    Does anyone have a part number for the DLE's.
    I might have found the number of the DLE's that ORD supplies with their crossover steering, Moog # ES2010L, ES2010R if i'm not mistaken. I just found the card i wrote those numbers on, can anyone confirm that this is correct?
  2. cok5
    cok5 Registered Member
    Apr 27, 2004
    89
    You don't wanna run DLE's on a tie rod, I don't even like running DLE's on the drag link, they are long shanked and weak IMO. ORD uses either 2010L and 2234R's/2010R's on everything, they do not use DLE's since there DL is bent and puts it at much less of an angle. Looking at there pics I would say they are the 2010L&R. I would use the 2010L and the 2234R since the 2234R is quite a bit cheaper than the 2010R. They are nearly the same except the 2234R has a little longer shank.
    Check this out, http://www.partsmikeparts.com/tre_comparison.htm
  3. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    That's what i meant, i want to know if i can run the 2010L/2010R as a tie rod using the HD DOM tie rod from ORD. This way i only have 2 different ends on my rig.
    I just took a look at the site and it looks like i can run the same ends in my tie rod. :thumb:
  4. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    So back to one of my questions, what size tie rod do most of you run the use the ORD tie rod?
  5. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    The big one, I bounced it off several rocks pretty hard last time out and it's held up. More "research" to be done on Saturday. :D
  6. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    I'm running a 1.5" O.D. .375" wall DOM tie rod with TRE's. I bent it..but it's held up fairly well. If I had it to do again, I'd use 1.5" solid chromoly and just drill and tap the ends for 2 right hand TRE's from the parts store.
  7. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    1 1/4" Chromo tie rod, will bend like crazy but when the load is off it just springs right back to straight.
