tie rod
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by NEK5, Feb 20, 2006.
  1. NEK5
    NEK5 3/4 ton status Premium Member
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    alright i got a question. is the whole on the tie rod for the stabilizer threaded...i just swapped it out for a dual one and i no longer need that whole so now the bolt for it is in the tie rod and i can seem to loosen it for the life of me :mad: i really didnt wanna wack it with a hammer in case it was threaded
  2. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    dont think so, i went to dual, couldnt get it out so i just left it in there.
  3. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    well if i cant thats what i will be doing
  4. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    It might be tapered and need to be wacked with a hammer. The taper would let it lock in place and prevent any undo wear in the tie rod which could cause it to fail. Give it a good smack and see what happens.
    Ira
  5. K5Kell
    K5Kell Guest
    Try heating around the hole with a torch, that should help pop it out.
    -Kell-
  6. neverendingproject
    Jul 24, 2005
    1,637
    Tulsa, OK
    After thinking about it, it probably strengthens the tie rod, because you have filled that material with something solid instead of having a hole there.
  7. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    Its a slightly tapered fit. Use an impact and a pry bar to put a little force against the threads...it should come right off.
