Tie rod ?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by dmanblazer, Feb 27, 2007.
  1. dmanblazer
    dmanblazer 1/2 ton status
    Sep 5, 2004
    165
    Wellington, Kansas
    I found a set of 3/4 ton axles off a sub for $400.The front end is missing the tie rod. Will my 10 bolt rod work in it's place? I don't have any knowledge of Dana's so I'm hoping it is a 60, if not I'm not going to buy them. The seller doesn't know either. They are 8 lug though, and I plan on running 38's or 39's with hopefully 4.10's.
  2. Dudge
    Dudge 1/2 ton status
    Sep 9, 2006
    351
    Kentucky
    It is more than likely an 8 lug Dana 44 or 10 bolt. To my knowledge they never put 60's in 3/4 tons. Someone else might be able to back me up on this.
  3. k30bb468
    k30bb468 1/2 ton status Premium Member
    Oct 2, 2004
    955
    NW Pennsylvania
    X-2
  4. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    Stock on a 3/4 Burb is a 14bsf and a 10b. 8-lug. The tie rod whould be fine.
  5. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Depends on years but some years had a 14bf rear but all 3/4 ton subs had D44 or 10bolt.
    The only way this would be a D60 is if the previous owner swaped it in. :D
  6. dmanblazer
    Sep 5, 2004
    165
    Wellington, Kansas
    Well it's not a 10 bolt front but it is a 14 bolt rear I know what they look like. It's probably a 44 I need to take some pictures of them. And I thought I found a good deal, oh well!
  7. onetonbb74
    onetonbb74 1/2 ton status
    Dec 1, 2005
    2,083
    Campbell, CA
    the tie rod will work, the knuckles must be from the same axle ie 10 bolt to 10 bolt or 44 to 44.. No dana 60f in subs period unless swapped and if its swapped, the owner would probably know about it.
