Tie rod?
Discussion in 'The Garage' started by MTBLAZER89, May 14, 2003.
  1. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    I just bought this 8 lug 10 bolt and the tie rod has a slight bend in it (if you lay a straightedge on it it's bent about a 1/4"). How much of a bend is unsafe to use? I can use the tierod under my truck, but I want to build this axle without having to take my truck apart. Thanks.
    -Brian
  2. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Well, that amount of bend doesn't sound too bad. Here's what I'd do. Install the tie-rod and just lengthen it the proper amount to give you about 3/16" toe-in. But, just so you know, having a slight bend in it makes it weaker, so it's just that much more prone to bending offroad. On-road, you should be fine.
    Probably the best option is to build the 8-lug 10 bolt, and then on the day that you swap it in place of your 6 lug 10 bolt, swap the tierods too. That's what I'm going to do. /forums/images/graemlins/thumb.gif
  3. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Maybe you could slip a slightly larger tube over it and weld it on...
  4. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Get a sleeved Rock Rod. You will never have to worry about bending a tie rod again with one. I just picked one up from 4x4 Iron and this thing is BEEFY. I will never be able to bend this thing. Tim told me my steering knuckles would probably break before the tie rod bent. It only cost me $167 for something that is bulletproof and I will never have to worry about. Worth the extra cost for the piece of mind.
  5. jekbrown
    May 19, 2001
    45,030
    363
    Vancouver, WA, USA
    I have a rockrod from Rockstomper. Pics in webshots. high quality product and purdy cheap too. Think they are $170 now... lil cheaper when I got mine i think.
    rockstomper
    j
  6. TheLakeRat
    TheLakeRat 1/2 ton status
    Nov 29, 2001
    363
    San Angelo, Republic of Texas
    Sorry to pimping but if you want a new one then give me a call and i'll build you one that you can't bend. I'll evven give it a lifetime waranty.
    I can jack mine up on the tie rod.
    I can tap the ends to whatever thread you want.
