Tie Rod
Discussion in 'The Garage' started by Muddytazz, Aug 21, 2003.
  1. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    I got a new tie rod from sky-manufacturing, nice and beefy.
    What I'm needing to know is, when I install it on my D44, oh do I adjust the TRE's?
  2. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    If the tie rod is threaded with both right & left hand threads,
    just bolt the tie rod ends into knuckles and twist the tie rod to set the toe.
  3. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Setting the toe in is what i need to know, i've never done that before. I just want to get it close then I'll take it in to have the front end aligned.
  4. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    Measure the distance of the left front center to the right front center of the tires. Then measure the same spot on the rear part of the front tire. Make sure your measurements are parallel to the ground! The front should be 1/8" to 1/4" narrower than the back.
  5. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    And when you get that done, there is nothing else to align, so don't waste your money at an alignment shop.
