Tierod\Drag Links & Ball Joints
Discussion in 'The Garage' started by 2High4U, Dec 16, 2005.
  1. 2High4U
    2High4U 1/2 ton status
    Aug 20, 2005
    542
    Felton Pennsylvania
    Im changing m front and rear drag links tierods and ball joints tommorow
    because they are all bent any good methods to getting the alignment close?
    Do I need to use a fork to remove the drag links or can i just remove them with bfh?
    and the last question... the steering stabalizer i have is a aftermarket pos and think its on worng to boot, which side of the shock goes where(does the part that doesnt extend anywhere go on the axle or on the tierod)
    thanks
    One day away from picking up my 400 small block, 500 cad motor and 16.5 6 lug aluminum rims:D :D :D I can smell a truggy on its way on a burban frame:eek1:
  2. 2High4U
    Aug 20, 2005
    542
    Felton Pennsylvania
    Any Suggestions At All?
  3. 3rdshiftdesign
    3rdshiftdesign 1/2 ton status
    Feb 6, 2005
    259
    Bucks County, PA
    Count the threads and mark them. yellow paint marker, or if it's clean enough spray paint.. just to get an idea, then count the threads.
    I just replaced all of mine and didnt use a fork. Just tap the knuckle to drop the tie rods, and same for the drag link ends.
    The part of the stabilzer that spins (just the shaft end) goes to the tie-rod.
  4. 2High4U
    Aug 20, 2005
    542
    Felton Pennsylvania
    alright thanks for the advice this is the first time doing this except for the ball joints i have done them before... just didnt want to screw anything up too bad until i can get an alignment
