tight and sticky throttle
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by gill, Mar 6, 2002.
  1. gill
    gill Registered Member
    Aug 3, 2001
    37
    memphis and murfreesboro, tn
    Hey guys it been awhile since I have been on, I have a very aggrevating problem that I have been putting off for the longest time. When I push in on the throttle it hangs in the throttle body and then I end up stomping the hell out of it when it finally goes, and I believe it is messing with my TPS and screwing it up also givin it false readings, I have replaced both the sensor and the wiring harness and it still messes up
    So any help on this is very much appreciated or anyone else having this same problem
    Thank Ya
    Gill
    88 K5 350 4" 35x12.50-15
  2. 4x4k20
    4x4k20 1/2 ton status
    Mar 17, 2001
    1,699
    williamson ga.30292
    take some carb cleaner and clean the butterfly in you tbi or you made need to replace you throttle cable .cleaning it will help alot
  3. RESTORE89
    RESTORE89 1/2 ton status
    Jan 31, 2001
    548
    CHAS SC
    does it stick if you work the throttle by hand under the hood?
  4. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    Throttle body casting is worn. You can have it rebushed with bronze bushings. Personaly I'd just take it to a dealer and have it done, insted of messing around with it your-self.
  5. MOABDADC22
    MOABDADC22 1/2 ton status
    Jul 24, 2001
    1,348
    Cheyenne, Wy
    I think TWIZ is right. I f you have cleaned everthing and all the sensors are up to par. You might have worn a groove that your butterfly is hanging up on.
  6. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    It's not so-much the throttle blades wearing-into the body, as it is the shaft-bore getting elongated and the blades ending up-binding on the bore. Just to make it clear.
  7. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    Gill.
    This sounds like the throttle body-bore is worn by the throttle shaft. Causeing the throttle blades to bind in the bore.
    To check. Grab the throttle shaft and wiggle it, it shuold be solid, and only have rotational movement.
    I think takeing the throttle body to a dealer, or a shop that is equipped to repair the throttle body is the best, and most efficiant way to go. Because, inorder to repair the throttle shaft bore, it needs to e drilled, reamed, bushed and wedged (all specialt tools)- so I don't think it would be a wise choise to do-it-yourself.
    Save yourself some cash and pull the TBI yourself and bring it to the shop. (call 'em beforehand, and get a quote)
    If you do plan on pulling the TBI your-self, the fulel0lines can be tuff to remove, loosen the bolt on the back ofthe head that holds the fuel lines inplace (I thinks it's the same set-up as on IFS trucks ?!!?!) And keep an eye out for the fuel-line O-rings.
    Hope this hepls
