Tight clearance on 454??
Discussion in 'The Garage' started by txfireman110, Oct 24, 2005.
  1. txfireman110
    txfireman110 1/2 ton status
    Nov 1, 2003
    294
    San Angelo, TX
    Dropped a 454 into the mouth of the beast, and the clearance between the oil pan and the crossmember seems AWFUL tight. I used 350 motor mounts (i think) Any one else have this problem? Solutions?
  2. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,923
    333
    Fort McMurray, Alberta
    big block mounts will lift the engine higher than small block mounts :)
  3. mechted
    mechted 1 ton status Premium Member
    Oct 19, 2003
    765
    Granbury, TX
    or you can insert a spacer so you dont have to buy new mounts
  4. jays68yak
    jays68yak 1/2 ton status
    Feb 27, 2003
    973
    Gilroy, CA
    how close is close?
    custom crossmember, 454 on sb mounts.
  5. jaysonsk5
    jaysonsk5 1/2 ton status
    Aug 11, 2005
    229
    eastern iowa
    hey i have the same thing with my 454, are we talking motor mounts or motor mount buckets? i used my 305 buckets and 350 mounts, it has had this set up for all 5 small blocks and now a big block. btw how many cubes is a .30 over 454? i hear alot of people saying that they have 468s but i think that a .30 over 454 is more like 461 at .90 over its like 468? any one know for shure? :confused: :confused: :confused: :confused: :confused:
  6. BadBob
    BadBob 1/2 ton status
    Aug 14, 2005
    158
    Lyndon, KS
    .030 over is 460.4, and .060 over is right at 467 and change
  7. Shawn
    Shawn 1/2 ton status Premium Member Author
    1,753
    5
    5280'
    Having installed 2 small blocks and 3 big blocks, the engine mounts are pretty much the same you can use SBC mounts for a BBC. The only thing thats different, is where they mount to the frame and the holes. Your mounts might be worn. Replace with new mounts or install Energy poly mounts. I never had a problem with SBC mounts contacting the crossmember even with my 496 doing wheelies in the parking lots! :D
  8. thatK30guy
    Jan 12, 2001
    32,076
    55
    But......almost 99% of rebuilders call their .060 overbored 454 an actual 468. :thinking:
  9. jaysonsk5
    Aug 11, 2005
    229
    eastern iowa
    hey guys thanks for clearing that .30 over thing up. :bow:
    how far away is your oil pan from the cross-member?
    mine looks like it might be touching :confused:
  10. mechted
    Oct 19, 2003
    765
    Granbury, TX
    for my 396 in a 73 K5(stock x-member) its about 1/4" or so...
    its one of those things i keep meaning to address...
