tight throttle
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by gill, Oct 4, 2001.
  1. gill
    gill Registered Member
    Aug 3, 2001
    37
    memphis and murfreesboro, tn
    Im havin a problem with my tbi sticking. It is always hard to press on the gas pedal from a light and when I finally to get it to go I usually end up stompin it. Any kind of feedback would be much appreciated cause this is one of those problems that get to you after a while.
    88 College K5
  2. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    few things you can do;
    check the spring, make sure you're not using 5 of them.
    check the linkage that goes to the carb, sometimes they get kinks.
    check the clearance under the pedal, sometimes the carpet gets in the way.
    ARQ.
    offroad baja!!!
    1-72 4x4 CST Blazer
    2-71 4x4 CST Blazer
    <a target="_blank" href=http://coloradok5.com/gallery/ArqDennis>My Pics</a>
  3. Itali83
    Itali83 1/2 ton status
    Feb 12, 2001
    795
    Westbrook Maine
    I say it is the cable, that did it for me.
    Ben 87 Jimmy
  4. newyorkin
    newyorkin 1 ton status
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    Gill,
    I'd say check all of the above, then try a few more things;
    Is it the same symptom with the engine off?
    I have/had the same problem for awhile now. The throttle shaft bore can wear out, causing the throttle plates to move a hair when closed and vaccuum is applied (engine at idle). Then, when you try to open them, they stick against the side of the TBI bore, and eventually pop open with enough force.
    See former post:
    k5.8m.com
    Welcome to America. <P ID="edit"><FONT class="small">Edited by newyorkin on 10/04/01 10:34 AM.</FONT></P>
