Tighten up drivers side mirror
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BranndonC, Sep 27, 2002.
  1. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    How can i tighten up drivers side mirror? do i have to take it off first or something. it won't stay where i set it, it waves around loose. /forums/images/icons/confused.gif /forums/images/icons/confused.gif /forums/images/icons/confused.gif
  2. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    Are they the style of mirror that is fully on the door? If it is, there's a star screw on the bottom of the mirror base. After you get that off, slide the base up the mirror, and you will see the mirror post clamped with I believe three nuts, 9/16th? Tighten up those three nuts.
  3. Greg72
    Mar 5, 2001
    15,681
    1,392
    642 Days to BB2018
    Brandon,
    It's slightly cheesy but here's what I did....
    First unscrew the lower screw and the outer cover shell will come off.
    On the inside the mirror is clamped with a little strap and a screw or bolt. All I did was to cut a thin strip of aluminum off a Coke can (OK, it was a beercan!) and use it as a thin shim between the mirror post and that clamp to get more "clamping force"...depending on how loose it is, you might want 2 or 3 thicknesses to get it nice and tight.
    Try it, it's cheap and it works.
  4. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    .....and it gives you an excuse to drink beer!!
  5. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    damn Eric, is that all you think about!?!? /forums/images/icons/grin.gif
  6. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    thanks everyone, i fixed it... the screws were 11/32 by the way.. thanks again
  7. Bubba Ray Boudreaux
    Jan 21, 2001
    20,716
    I like your thinking.
  8. dyeager535
    26,978
    Bicycle inner tubes cut in half work ok too, but no excuse to drink beer, except all that hard work /forums/images/icons/wink.gif
