Tightening wheels bearings?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by FL84K5, Jul 23, 2002.
  1. FL84K5
    FL84K5 1/2 ton status
    Aug 19, 2001
    936
    Sarasota, FL
    I went to have my truck aligned today and they said they wheel bearing in my left front tire were loose. Either that or maybe it was wheel nut, I can't remember exactly what was said. How hard is it to tighten this? He said the hub has to be taken apart to get to it. How do you take the hub apart? Is it something that someone who is just learning to work on trucks can do? Are there any special tools needed? This is on an 84 with Mile Marker hubs
  2. jackedjimmy
    jackedjimmy 1/2 ton status
    May 18, 2002
    195
    Redmond WA
    there is a special tool needed (atleast for warn hubs) that is a large socket with 4 prongs on the end. You need this to take off the the spindle nuts ( i think thats what there called)
    But beforeyou get to those, you have to remove all of the outer hub assembly.
    Good luck
  3. bobsurf
    bobsurf 1/2 ton status
    Jun 26, 2001
    410
    San Marcos, CA
    Yep, just the big Hub socket described above, plus you'll need a torque wrench to seat the bearings. It's a pretty simple puzzle, and most books (chilton, etc.) have the correct process for torque(ing). It's something like tighten to 80lbs, back off, then re-tighten to 25lbs. Look that up though.
