Tighter steering
Discussion in 'The Garage' started by xblaxermnx, May 8, 2006.
  1. xblaxermnx
    xblaxermnx Registered Member
    May 31, 2004
    62
    In a state of flux
    OK, so I have a 4 in lift, 33 in tires. I know it wont corner like a vette, but the steering is kinda loose and when I panic break it pulls bad to the left. When I lift the front suspension off the ground, every thing seems tight. What have you guys found to tighten up the response and controll of your rigs?
  2. Propayne
    Propayne Registered Member
    Nov 27, 2005
    67
    San Angelo, TX
    i have the same lift/tire combo as you, and believe me your steering wont get much better unless you spend some dollas$$$. i make 5 point turn arounds on streets.
    for the pulling, check your brake pads to make sure one side isnt wearing more than the other...also check to make sure your leaf springs/shackles line up to your frame, then make sure all that lines up to your shackles.....etc
  3. bigbadchev84
    bigbadchev84 1/2 ton status
    May 17, 2004
    2,191
    Hermiston, Oregon
    what do you have for steering correction?
  4. xblaxermnx
    May 31, 2004
    62
    In a state of flux
    Umm, steering corrction?:crazy:
  5. Propayne
    Nov 27, 2005
    67
    San Angelo, TX
    stabilizer? drop pitman arm? any of those?
  6. xblaxermnx
    May 31, 2004
    62
    In a state of flux
    Oh, I do have a steering stabilizer, brand new. Pitman arm, is stock
  7. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    So you don't have a raised steering arm or a dropped pitman arm? If you don't I'd suggest getting a raised steering arm, get that draglink back to horizontal. You might also want to brace up your frame, either weld in/bolt on or both. Check your frame for cracks behind the steering box. Also check your wheel bearings, that was the culprit when I had brake-steer. Balljoints can cause that too. TRE's, DLE's, etc. Lot's of things to inspect. Leave the truck on the ground, have somebody crank the wheel back and forth while you look for movement.
  8. RootBreaker
    Nov 29, 2001
    5,118
    173
    Williamstown, NJ USA
    I recommend all he said too.....
    in addition you could get a raised steering arm...
    I have a drop pitman arm that is good for 4-6" if you wish.... sell it to ya cheap :wink1:
  9. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    Do this either way. It improved my steering a lot and now I don't wory about cracking the frame.
  10. pvfjr
    Feb 10, 2004
    2,425
    Oakridge, OR
    Yeah, I can't wait to drive mine again after going from this:
    To this:
  11. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
    what's the difference in the pics?
  12. pvfjr
    Feb 10, 2004
    2,425
    Oakridge, OR
    Check again, you caught me at a very untimely moment. :p:
  13. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    ahh, yes, i look forward to going to the trusty painted option someday too when i can spare 30 cents for a rattle can. :D just kidding. i need to get one of those too.
  14. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
    I went from 12" of lift and stock steering with every correction (raised arm, dropped pitman, "Z" shaped draglink) to ~5" of lift and crossover
    Good lord it was like going from a shopping cart to a vette in comparison.
    X-over, if you have the $, is the way to go. Otherwise, try to get the draglink horizontal and correct using either the pitman arm or the steering arm
    Mike
  15. pvfjr
    Feb 10, 2004
    2,425
    Oakridge, OR
    Nah, the frame patch wasn't important. It was all about the Gloss Black. Honestly, have you ever seen such a beautiful frame rail? :laugh:
  16. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    well, when my bumper was missing on the front i did paint the two horns sticking out from under the core support and they might have posed a bit of competition. :D
  17. ZooMad75
    ZooMad75 1/2 ton status Premium Member GMOTM Winner
    Apr 5, 2003
    1,015
    617
    Pueblo, CO
    If you can't afford the x-over steering, then at least get the raised arm or dropped pitman other people have mentioned. I had 33's on when I installed my 4" lift and installed the arm at the same time. Besides having to adjust the draglink to account for the raised arm, the steering felt the same pre-lift as it did post-lift. Still not like a slot car, but same as stock.
    The closer you can get the draglink to parallel with the ground the better your steering will be. I had to shorten my drag link up a few turns because the raised arm put the drag link closer to the box. without adjustment it took the steering gear off center so I had only 2 turns of the steering wheel in one direction and 4 turns in the other direction. This made for really tight turning to one side and wide as school bus turning to the other.
    either option you choose you have to adjust the draglink to account for the changes made.
  18. xblaxermnx
    May 31, 2004
    62
    In a state of flux
    Thanks for all the input, One question I have what is involved with a cross over steering upgrade? Is it something a mediocore shadetree mech do? What is involved?
  19. Kyle Strong
    Kyle Strong 1/2 ton status
    Sep 26, 2005
    280
    Eugene, OR
    Not meaning ot hijack, but he may want to know too. How do you adjust your draglink? Because I have the same exact problem, and it sucks!:mad:
  20. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    i don't have proper language, but there's two bolts on a sleeve on the drag link - loosen those and then turn the sleeve - this will shorten or lengthen the drag link. tighten up the bolts and you're done. pretty easy.
