tilt colum will it fit?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by mudhog, Aug 12, 2001.
  1. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    i have the opertunity to get a tilt colum from a cadilac not sure of the year yet but is there a chance it will fit in my 77blazer?
    wheeling videoshttp://community.webshots.com/user/ssmith6333
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
  3. thatK30guy
    Jan 12, 2001
    32,076
    55
    I have no clue. I have heard of some car type columns being interchangable with the trucks, but dont know exactly which ones.
    I think back when I was in jr. high, my dad took a column from a Pontiac Grand Safari and swapped it into his '80 K10. When we got rid of that truck, I remember the column still being that 'greenish' color from the car. So, it must have worked.
    <font color=blue>Daddy told me while learning to pee......"if you shake it more than twice, then you are playing with it!!!"</font color=blue>
  4. tRustyK5
    Jul 23, 2000
    36,173
    1,384
    E-town baby!
    I was told that most GM columns interchange...but I haven't swapped one myself to confirm that.
    The Camaro columns apparently are the ones to snag if you have a standard tranny because they don't have the column shifter on them, and they usually have a nice steering wheel.
    Rene
  5. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    I have a buddy that swapped a caddy column into his CJ5. I'm not sure if he had to any mods though. That doesn't really answer your question[​IMG], but at least it shows that the swap can be done....
    <font color=red>PHOTO ALBUM-</font color=red> <a target="_blank" href=http://albums.photopoint.com/j/AlbumList?u=1289798>http://albums.photopoint.com/j/AlbumList?u=1289798</a>.......<font color=blue>TRUCK & HIKING PICS</font color=blue>
  6. mudhog
    Nov 6, 2000
    17,899
    portland oregon
  7. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    Shannon the column is out and I will go over and take some measurements and see what the mounting looks like .
    I'll also see what kind of doo-dads are on it too.
    my truck's not dirty, it's earth tone paint
  8. mudhog
    Nov 6, 2000
    17,899
    portland oregon
  9. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I wouldn't put any tilt GM column in my truck. I had to swap mine out because I broke it from using it to drag my 5'4", 125 lb. butt in my truck.
    Tim
  10. 4x4_76
    4x4_76 1/2 ton status
    Jul 22, 2001
    628
    Ylämaa, Finland
    If I remember correctly,my friend had Caddy column on his -77 C-10.Steering wheel moved horizontal and vertical on that...
    I'm too lazy to stick shift,that's why I prefer autotranny.
  11. dyeager535
    26,979
    It would likely bolt up, but the length very well may vary. As long as it isn't a telescoping version, the parts will interchange with all similar GM columns, which is basically all RWD applications from 73-mid 90's. Wiring is going to be different most likely. (wipers on column maybe, high beams on column, door chimes, key in ignition) Cheap is less than $50.
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>http://www.dorianyeager.com/index2.html</a>
    No anti-theft measures on your truck? No pity when its stolen
  12. mudhog
    Nov 6, 2000
    17,899
    portland oregon
  13. Wheels
    Wheels 1/2 ton status
    Aug 18, 2000
    638
    Let me know how it fits. Need to upgrade mine with a OD column shift and $150 is the going price around here...
  14. POWERMAD
    Mar 4, 2001
    3,466
    Oregon
    Shannon I have not gotten a chance to go look at it yet butit is a telescoping column.
  15. mudhog
    Nov 6, 2000
    17,899
    portland oregon
  16. dyeager535
    26,979
    Telescoping columns are really cool (more worthwhile than tilt IMO) but I know that my dad did NOT use the complete telescopic column in his truck, but he modified the pieces of it, and the truck column, to get a tilt/tele in his truck. I think part of it was that his is a manual trans truck, so no column shift unlike the Caddy ones which AFAIK, were ALL column shift.
    Telescopic should have been the option, not tilt, since if you need to move the wheel, typically its because you have shorter or longer arms, which is solved by being able to move the wheel closer to you.
    Dorian
  17. mudhog
    Nov 6, 2000
    17,899
    portland oregon
  18. dyeager535
    26,979
    Well, you can make anything work if you try hard enough. You are just going to have to compare overall length. If you don't mind that handle hanging off (or remove it) and the length is right, it will work. I seriously doubt in any case, that it will be a direct bolt in, due to at LEAST wiring differences. That telescopic part makes using non telescopic parts a tough question, as the telescopic is quite different internally from teh non telescopic....if the length is right, and you don't mind the shifter, i'd say go for it. Otherwise, go buy one thats a direct drop in for $50 or $75, because you WILL spend that much time working on getting a non-bolt in column working in your truck.
    Dorian
  19. mudhog
    Nov 6, 2000
    17,899
    portland oregon
