Tilt column help please...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by chevyfumes, Jun 23, 2003.
  1. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    I'm tearing it down to tighten it up and I got to the turn signal, were you unscrew it and pull it out and let it hang by the wires and heres the problem....It won't pull out far enough.....It's a 74 if that helps, I don't want to pull too hard on the signal harness,I'm afraid it'll break, so WTF guy's, anyone????? /forums/images/graemlins/shocked.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif
  2. Rolled
    Rolled 1/2 ton status
    Jun 16, 2002
    683
    Anchorage, Alaska
    It won't pull out far enough for what?
    The plug towards the bottom of the column slides into some tabs on the column. Slide it out and you will get a couple more inches. If you already did that then tie a string to it and slide it up inside the column.
  3. chevyfumes
    Feb 24, 2000
    38,584
    266
    [/ QUOTE ] to get to the screws behind it, I finally got to them but what is this plug, I don't have anything like it but I can get to the pins on either side but can get them out, even with the make shift screw and socket puller.... /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gifThen out falls a small stip of metal that resembles part of the turn signal, but I hvent a clue where it came from..... /forums/images/graemlins/crazy.gif
  4. chevyfumes
    Feb 24, 2000
    38,584
    266
    [/ QUOTE ]Yeppers it was part of the signal pod, now only my left rear blinker works....Is it time for a drink yet????? /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif
