tilt column in 70 K5
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by mcmlxix, May 7, 2003.
  1. mcmlxix
    mcmlxix Registered Member
    Nov 28, 2001
    80
    Las Vegas
    What tilt column will fit in a 70K5 thats a floor shift. I remeber someting about a 73 van? I searched but didnt find anything on what will work.
    Anyone running and Ididit tilt column?
  2. 6869704x4
    6869704x4 Registered Member
    Aug 1, 2002
    42
    NW Fla
    I put a van tilt in my 70 truck. Im not sure of the year it came out of. Prior to whenever they put the key in the column. It had a flat plug instead of the curved one. My old 73 van had a curved plug but it was non tilt. Not sure what year they changed plugs.
    It had two notches in the column that mate up with the tit on the dash. If you use the lower one you should be OK since you dont need the neutral/backup light switch on the column. If you use the upper one, like I did because I wanted the wheel further away from my fat gut, youll have to clearance the dash bezel a little(I think). I didnt try to fit up the stock steering shaft and ragjoint. I used coleman racecar ujoints and rod to make a new one. Can send you a pic if you want.
  3. Rusty68
    Rusty68 1/2 ton status
    Jan 22, 2003
    116
    Elko, Nevada
    I would like to see pictures of that steering rod set-up if you dont mind. Some of the pre built shafts are spendy so I was wondering how I could build one myself to save some cash.
