tilt column parts availability...
Discussion in 'The Garage' started by ryoken, Sep 26, 2004.
  1. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    my 87's tilt had a bunch of slop when i bought it. i let it go awhile and it now has apparently chafed the wires leading down from the turn signal actuator.. i've gone in and tightened up the slop but need to go back in to replace the wiring assembly or repair it... just as soon have a new one sitting there next time i tear the column apart..
    anyone know if this is available thru GM? or have an exploded view of a mid 80's tilt?
    i'd just as soon get a non-tilt manual one and put a floor shifter in, but for now i need to fix this... thanks for any help...
  2. sickquad
    sickquad 1/2 ton status
    Jul 23, 2003
    785
    Ma
  3. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    tho the one post goes a little deeper then i ventured, the link to the exploded is no good.. /forums/images/graemlins/frown.gif thanks tho...
    gonna stop by my local GM monday and see if the turn signal/wire assembly is available... shouldn't have to go in quite as far to replace that as i did tightening the slop.
  4. or2play
    or2play 1/2 ton status
    Feb 22, 2002
    657
    Yuma, Arizona
    Your dealer should have the turn sigal switch in stock. They also have a kit that has the ignition rack w/all the parts to it, and the two bearings that go inside the tilt bowl.
  5. dyeager535
    26,980
    Get the part number from the GM dealer, and plug it into gmpartsdirect.com
    Also have a friend that can get Delco stuff, so if it's a Delco piece, he can probably get it for less than GMPD.
    My local dealer absolutely shafts you on parts, and there is NO reason to buy from the dealer when they charge you (typically) 50% more than GMPD.
    Delco part number appears to be D6225, but I would verify that with the dealer, it varies on RPO apparently.
  6. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    cool, thanks... i have Delco capability too, so i'll double check the #'s and call him..
    muchos gracios /forums/images/graemlins/thumb.gif
