Tilt Column question
Discussion in 'The Garage' started by Russ, Dec 25, 2006.
  1. Russ
    Russ 1/2 ton status
    509
    Summerdale AL
    Does anyone know if it is possible to convert an automatic tilt steering column to manual, other than just taking the auto shift lever off? I recently put in a tilt column in my crewcab and have now decided to do a manual conversion. I have become quite fond of the tilt column though and do not want to lose it.
    If it cannot be converted, was a manual tilt column ever made? Do any of the newer 88+ C/K style columns work in the 73-87 bodystyle? Thanks for any help.
    Russ
  2. 3rdshiftdesign
    3rdshiftdesign 1/2 ton status
    Feb 6, 2005
    259
    Bucks County, PA
    It's easiest to just take the shift lever out. Some people have taken them apart, ground off the nub to hold the shift lever on and covered it up.
    I dont think it looks bad if you just take the lever out, and you always have an option to go back to auto if you need to swap trannys!
  3. bronc3buster842001
    bronc3buster842001 1/2 ton status
    Sep 30, 2006
    1,996
    6
    leadwood missouri
    or u could find a camaro that had a manual with tilt and swap the parts i put a complete camaro column in my old truck just got to make the shaft longer under the hood
  4. dyeager535
    26,979
    Yes, column in my truck is from an auto truck, took the manual shift column bowl from a G-body and swapped the auto truck upper bowl.
  5. Russ
    Russ 1/2 ton status
    509
    Summerdale AL
    Thanks for the help everyone. That sounds easy enough to swap the parts out.
    Russ
