Tilt Column Question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Redfrog, Dec 18, 2001.
  1. Redfrog
    Redfrog 1/2 ton status
    May 4, 2001
    753
    IL
    I have a Tilt column out of a 82 with column dimmers, And I want to put it in a 79 . Has any body ever took the dimmer mech out of a dimmer style column and put a older style
    neck on the in place of the dimmer style neck? Are the
    turn signal switches the same? or would I be better off
    just wiring up the dimmer to the column? Any info would be great Thanks
    *wink*
    my 79 rust bucket will run over your 2001 chevy 4X4 tahoe plastic wagon
  2. dyeager535
    26,976
    Dimmer wasn't on the column in '82, (my '83 was still floor)but that really doesn't matter as long as it has it.
    I'd say wire it up with dimmer on the column, less likely to short out, break, corrode from water, whatever. I think the dimmer is a little safer from my feet on the column.
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>www.dorianyeager.com/index2.html</a>
    Why insist on counting when the ring gear has the tooth counts stamped in?
