tilt/dump bed ?????
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by DUKSRULE, Nov 4, 2002.
  1. DUKSRULE
    DUKSRULE 1/2 ton status
    Nov 25, 2001
    303
    Va Beach Va
    I have an 86 longbed truck that I use around the house. I am thinking about getting one of those dump bed kits for it. The one I looked at said the rear bumper gets welded to the bed hinges. To me this would mean no towing from the bumper. I have a reciever hitch on this truck and am wondering if the dump bed would work with it. Anyone have a dump bed on thier truck? If so how did you do it?
    TIA
  2. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    You can still run a bumper hitch assuming you have enough bracing and the hinges and supports from the hinge to the bumper are strong enough (not recommended for heavy tow loads). You can run a regular "Reese" style hitch, but may have to "adjust" it's mounting location to clear the hinges for the dump bed and to make sure you have clearance from the bed and bumper when body is dumped. You can usually do it, but will have to remove the part of the hitch that goes into the receiver when dumping.
  3. DUKSRULE
    Nov 25, 2001
    303
    Va Beach Va
    That is what I was thinking. Just wondering if anyone had done it.
  4. Leadfoot
    Nov 28, 2000
    3,112
    My 80 originally had a flatbed with dump, but no bumper, but it did have a reese hitch. I have seen some with fleetside bed, bumper, and hitch. The hitch was moved forward and they used a longer than average "hitch" to make up the difference. The only problem was they had to remove the hitch when dumping or they would taco the bumper on the hitch.
