tilt front end
Discussion in 'The Garage' started by blazerdude69, Nov 10, 2004.
  1. blazerdude69
    blazerdude69 Registered Member
    Jan 10, 2004
    22
    has anyone done this or know of a web site that might have some info. I'am thinking of tilting the front on my 84 Blazer I believe that it would make it easier to work on the motor insteak of haveing to climb up an sit on the radiator or try to stan on the stock front bumper. any help would be great.
  2. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Cybrfire did it I believe. Made it all one piece then hinged the front. /forums/images/graemlins/waytogo.gif
  3. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    Someone else has done this (can't think of who it was)and they said it sqeaked so bad it drove them nuts.... /forums/images/graemlins/dunno.gif
  4. blazerdude69
    Jan 10, 2004
    22
    does anyone know what is needed (parts) to do this? Or is there a write up about it?
  5. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    There is another shot of it in my gallery. No write up but I've got quite a few photos. Be out the rest of the day but I'll check back when I can.
  6. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    There used to be a kit you could buy ten maybe fifteen years ago I wanted for my K-10. Haven't seen it advertised in a long time though. Included hinges and rubber hold downs.
  7. joshua632
    joshua632 Guest
    I did it to mine before deciding to go hybrid. I also narrowed mine at the same time. Very time consuming but turned out nice I will give you the whole front end if you come get it. /forums/images/graemlins/cool.gif
  8. sickquad
    sickquad 1/2 ton status
    Jul 23, 2003
    785
    Ma
    Tilt front end is so nice. Every vehicle should have a complete tilt front end.
  9. Jeromy Gibson
    Jeromy Gibson 1/2 ton status
    Apr 17, 2003
    127
    Amarillo Texas
    I did it to my truck when I narrowed it, wasn't that hard to do. I would show you some pics but they are not very good and I have no way to post them. I will say this, I have never had an easier time changing the spark plugs, and the only thing that sucks is it the way I have mine pined in the back it takes two people to open it.
  10. blazerdude69
    Jan 10, 2004
    22
    cyberfire what did you use for hinges? and how do you fasten the front to keep it from moving?
  11. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    For a hinge I used the 1/4" plate you see on the frame in the above photo. This is also a winch mount. On the top edge of the plate there are bushings welded to the plate. Then there are plates welded to the core support and mating bushings. I used 3/4" bolts for pins. The bushings are spaced apart so tightening one bolt and loosening the other gives you side to side adjustment on the alignment of the front end. The reason I put the hinge point as high from the frame as i did was to create a place for the winch to sit without being in the way when the front end tilts forward. I didn't get reall fancy with the pins in the rear for holding it all down. Just fabbed up some pins on the fenders.
  12. blazerdude69
    Jan 10, 2004
    22
    thanks for the info cybrfire. what do you mean by mating bushings? are they a special bushing or just same size /forums/images/graemlins/dunno.gif ?
  13. blazerdude69
    Jan 10, 2004
    22
    any more info cybrfire? /forums/images/graemlins/1zhelp.gif
