Tilt steering column took a dump!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Frogg89, Feb 3, 2003.
  1. Frogg89
    Frogg89 Registered Member
    Jul 29, 2002
    85
    Southern NJ
    My column is really loose. Is there a way to fix it, or am I better off just replacing it?? Ive had it apart and I dont wanna go in there again, its messy!!
  2. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Those four screws right at the bottom need to have Loctite on them or they work loose. Sometimes the end of the tube breaks off instead - then its screwed /forums/images/graemlins/eek.gif
  3. Frogg89
    Jul 29, 2002
    85
    Southern NJ
    I had it apart today and I dont even remember seeing those screws. I couldnt get too far because I couldnt get the turn signal actuator off the wires. Any help with that? Please.
  4. u2slow
    May 9, 2001
    2,217
    BC Canada
    I have a step-by-step assembly of a GM column right here. /forums/images/graemlins/thumb.gif
    GM column
  5. edman87
    edman87 Registered Member
    Oct 26, 2002
    42
    BAton Rouge, LA
    The end of my tube broke off while turning one day and locked the steering wheel-NOT FUN! I skidded into a ditch, luckily with no damage. So please fix your problem, or at least find out what the issue is, the alternative may not be pretty. Taking it apart and putting back together is pretty straightforward. The only hard part is getting the lock plate back on without the right ttool.
  6. pismorat
    pismorat 1/2 ton status
    Oct 29, 2002
    540
    California
    Anyone know if they make removable steering wheels for stock columns, like in nascar? The ultimate anti-theft device!! /forums/images/graemlins/truck.gif
  7. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Grant makes a kit that makes the steering wheel quick disconnect. </font color>
  8. Grim-Reaper
    7,385
    Atlanta
    This is a monthly question. Try hitting the search with key words like Tilt loose, loose steering.
    Big Burb has a very nice set of directions for this problem that you will find when you look.
