Tilt steering column ???
Discussion in 'The Garage' started by poinzey, Jan 16, 2005.
  1. poinzey
    poinzey 1/2 ton status
    Jun 16, 2004
    113
    Texas
    After yesterdays trip, the truck now seems to have a short in the steering column. If I pull up on the column, it shorts all power in the truck. Has anyone else experienced this? I need to get under the dash and look today, but could it be the ignition switch itself? Or would it be a problem with the linkage to the switch? I guess I need to fix this one soon, kinda anoying having the engine die everytime you turn. :D
  2. poinzey
    Jun 16, 2004
    113
    Texas
    ttt, and an update
    After looking at the column, it appears that it is not a short causing the problem. From what I can see, the column is causing the rod to the ignition switch to move just enough to kill it. Is there a rebuild kit available for the column, or will I have to find another one from a junkyard???
  3. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    i don't know about a kit, but u can rebuild it, every so often i see an ad in the local paper, for a buissness that speciallizes in rebuilding columns.
  4. dyeager535
    26,982
    191
    Is the steering wheel loose?
  5. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Have you tried moving the switch a bit first , IIRC the switch mounting holes are slotted a bit so you move it some :thinking:
  6. loafer
    loafer 1/2 ton status
    Aug 19, 2003
    634
    Lyman, Maine
    I had a similar thing happend to mine, except every time I would take a right-hand turn the ignition would shut off. I would have coast throught the turn and then restart. The tilt part of my column was pretty sloppy though.
    I wound up getting a used column from the junk yard. Cost $150.00 too!
  7. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    Yes, you can rebuild them. I totally rebuilt my column for $80. Unfortunately, you can only buy the kit from the dealer. But, if you want to save yourself some money, call teh dealer and get the kit part #'s. Then got to www.gmpartsdirect.com and order from there. Will save you approx. %40-%50 off the dealer cost.
    You will need to buy a steering wheel puller, spring plate compression tool, and a pivot pin puller (get them at Harbor Freight to save $$). DON'T try to do it without them. You will give yourself MANY headaches. Also, get the exploded column illustrations. PM Muddytazz, I think he may have them.
    Also, when you get it apart, there are 3 bolts in the base of the tilt mechanism that will need to be tightend. I put some loctite on them so I wouldn't have to do it again.
    Bottom line, I would not buy another one from the junk yard, I'd rebuild the one you have. Take your time and pay attention to where everything goes and you'll be fine. I find it helps to lay out everything in the order I take it off so that I can put it back on in the same order. That way you make sure to use all the parts and get them back where they need to go. A buddy drove my '74 the other day and commented on how tight the tilt column is. Too bad the rest of the rig isn't!:grin:
  8. aduff85k5
    aduff85k5 Registered Member
    Dec 31, 2004
    91
    florida panhandle
    hey this sounds like a common problem. i've got it too. how did the rebuild go and pointers. i'm gonna pm that muddy guy.
  9. mountain4x4
    mountain4x4 Registered Member
    Oct 13, 2004
    62
    rebuild kit part #s ?
    Could someone post the column rebuild kit part numbers, or how to locate such a kit. I called 2 Chevy dealers, the local dealer and Salee Chevrolet, and no luck. They just want me to pick out parts to order from the exploded pics. Please let me know what column the rebuild kit is for when you post the part numbers. My truck is a '90 Burban w/tilt...
    Thanks,
    Dave
  10. GM Man
    GM Man 1/2 ton status
    Jan 12, 2003
    549
    Denver CO
    I a similar problem in my 78 Jimmy. The steering wheel was very loose and it would shut my truck down also. So a buddy and I tore into the column and there are 4 bolts that needed to be tightened down, right after the tilt part of the column. I also put some red locktite on them also, so they wouldnt back out again. After that it solved all of my problems.
