Tilt Steering column....?
Discussion in 'The Garage' started by Da-Rock, Apr 20, 2006.
  1. Da-Rock
    Da-Rock Registered Member
    Apr 7, 2006
    18
    Sacramento, CA
    Does anyone know what kind of tilt steering column will fit a 1952 Chevy Pickup? I had a guy looking at GMC steering columns, but I don't know what year it was.
    If I can't find a used one I guess I can buy Ididit's steering column. A bit pricey......:crazy:
  2. RootBreaker
    Nov 29, 2001
    5,118
    173
    Williamstown, NJ USA
    everything fits... depends on how much ya wanna fab.... :D
  3. nemesis_pyros
    nemesis_pyros 1/2 ton status
    Mar 24, 2004
    229
    Winnipeg, Manitoba
    Haha I do infact know.
    It a tilt steering colum out of a late 80's oldsmobile cutlass cierra. The ones out of trucks are too long but the one out of the oldsmobile fits real good. I'm sure there are other applications that are the same lenth too.Wish I was near my truck i'd take some pics for you.
  4. nemesis_pyros
    Mar 24, 2004
    229
    Winnipeg, Manitoba
    Hmmm I guess he won't be able to see that pic.
  5. Da-Rock
    Apr 7, 2006
    18
    Sacramento, CA
    I have found other things listed for a 1969 - 1974 GM steering column. I have also seen the Oldsmobile listed as a possibility.
    Length does matter......(looks around:eek1: ) The current steerin column is too long and sits on ma gut! I measured the length and to the floor it measured 32" ;) .
    What length do you guys think will be right for a 6'3" 300lb person in a 52 pickup cab...........(without fabricating an extended cab :D )
  6. nemesis_pyros
    Mar 24, 2004
    229
    Winnipeg, Manitoba
    You'd like the Oldsmobile lenght one. Keep in mind that the column is going to be angled more up and down than in a car. This puts the Steering wheel tilted up quite a bit, even when you have the tilt all the way down. ( hope that made sence). We tried a column out of a late 60's early 70's and that didn't work so well, also tried one out of a 73-87 chevy truck and those are way too long. Another factor you need to consider is what seat are you using. We used the ones out of the same Oldsmobile, They fit great and are very comfortable. Although more leg room would be nice, those trucks are not made for big people.
    Is this just a stock truck or did you change the front suspension? Just wondering what direction your going with the truck.
  7. Da-Rock
    Apr 7, 2006
    18
    Sacramento, CA
    It is stock and we are sticking to mostly stock stuff until I have the money to get a front end and then drop a 327 in or something.
    Do you think that the Ididit steering column will be too long?
  8. nemesis_pyros
    Mar 24, 2004
    229
    Winnipeg, Manitoba
    Ah ok cool we did the camaro front clip and a 454. If I did it again I'd use one of those aftermarket ifs crossmembers or use a clip with the steering box infront of the wheels instead of behind. Although we got lucky and only needed to use one borgason double universal joint to connect the box to the column. (yes thats it. they were only a few inches apart)
    I'm pretty sure you could go the ididit column route. iirc you can get them any custom lenght you need and they do look nice but are pretty spendy.
    I'll be able to take some pictures of my truck the weekend after next if you want and show you how I have my interior setup.
  9. Da-Rock
    Apr 7, 2006
    18
    Sacramento, CA
    That would be cool. Any info helps when working on this..........:D
  10. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Any steering column will work but the early tilt columns had a 2" diameter body to them making them fit exactly perfect under the dash. The length isn't an issue because you just run it through the firewall untill you have it where you feel comfortable then make mounts for it and then an intermediate shaft with borgeson u-joints.
