tilt sterring repair Q.
Discussion in 'The Garage' started by Supreme70, Dec 11, 2005.
  1. Supreme70
    Supreme70 1/2 ton status
    Jan 19, 2005
    501
    Detroit, Mi
    I have the column apart up to the point where i can see 2 of the reverse torx screws but i dont know how to get it apart any father, has anyone done this and have pics, just cant seem to see what the hell is still holding it together.
  2. fwc
    fwc Registered Member Premium Member
    Nov 2, 2003
    84
    Northern Virginia
    I got the the point where I could see three of the four, two are easy to see, the third you have to look for. I tightend these three up and let it go at that. I think to get to the fourth for you have to use a puller to take out a couple of pins and such. Column is now tight and solid. Good enough for me at this point
  3. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    Ihave repaired a few of them. You will need a slide hammer and a screw, small metric size. Don't really remember the size exactly though.
  4. Supreme70
    Jan 19, 2005
    501
    Detroit, Mi
    I have a slide hammer, but where would the screw even go????
  5. Supreme70
    Jan 19, 2005
    501
    Detroit, Mi
  6. readymix
    May 30, 2004
    6,706
    26
    Use it to remove what is called the "pin Pivot" In this diagram. There is one each side of the column..............
    I can't upload the image for some reason. PM me your e-mail and i will send it right out:D
  7. readymix
    May 30, 2004
    6,706
    26
    Got It
  8. mechted
    mechted 1 ton status Premium Member
    Oct 19, 2003
    767
    Granbury, TX
    http://elcaminocentral.com/article95.html I made a pin extracter from like a #10 (or was it #8?) screw and nut and a 9/16" socket... maybe a washer too... i forget, but if you can find a screw to go into the pin, youre good to go
  9. Supreme70
    Jan 19, 2005
    501
    Detroit, Mi
    Thanks for the info and the link with all the pic's. sure will make the job alot easier now. K5 is the best site for any info on our rigs thanks a bunch again.
  10. k204dr
    k204dr 1/2 ton status
    Aug 27, 2004
    463
    TN
    most parts stores sell the pin retractors, and you can return them when you're done!
