Time for a driveway DEGREASE!!
Discussion in 'The Garage' started by K5thatShmobs, Mar 25, 2003.
  1. K5thatShmobs
    K5thatShmobs 1/2 ton status
    Sep 27, 2001
    353
    San Luis Obispo, CA
    I have some DEEP grease stains (ATF, gear oil, brake fluid, axle grease, everything) all over my driveway from the last 6 months of intense work on the truck. Ive tried a few conventional degreasers, but none have done much at all. Can anyone recommend a VERY STRONG degreaser?
  2. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    hydrochloric acid
  3. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    I have a hand held sandblaster that I use when I spill... /forums/images/graemlins/thumb.gif
  4. Blaze
    Blaze 1/2 ton status
    Aug 28, 2000
    3,285
    Raleigh, NC
    Castrol Superclean worked on my old driveway. I poured it on full-strength and then scrubbed it with a stiff broom. Then rinsed and it looked fine!
  5. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    The bad thing with the acid is it eats the concrete, and leave big pours. So the next time you get oil there it seeps deeper into the concrete and it is imposibble to get it to look clean again. I haven't found any thing that really works, If the oil has been on the concrete for day or two brake cleaner or laquor thinner work to some degree.
  6. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    I always keep a gallon of Castrol Superclean in the purple jug for the same reason.
    You know, they also sell small powerwashers that would probably work great too.
    -- Mike
  7. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    i was KIDDING /forums/images/graemlins/grin.gif
  8. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Something that sort of works for oil stains is to get a bag of concrete and spread it on the stains. Brush it and scrub it in with a broom and let sit for a while. It sometimes can dramatically reduce the contrast, though you'll still see the stains.
    On a related note:
    A while back, after triming the bottoms of both my D60 and C14 (and some other cutting and grinding) I did not clean up the mess right away. It rained the next day and it was a week or so before I got back to working on it (and clean up). Oops! Now I have enormous bright orange iron oxide (rust) stains over the entire area. How the ???? do I get rid of that?
  9. ds350
    ds350 1/2 ton status
    Jan 26, 2001
    190
    Bay Area
    Try a Steam Cleaner.....??
  10. Ryan B.
    Jul 18, 2001
    5,693
    CA
    Soak the grease stained area with simple green for an hour.
    Then pressure wash it. /forums/images/graemlins/thumb.gif
    You'll be pressure washing the whole driveway though so it will all look the same then. /forums/images/graemlins/eek.gif /forums/images/graemlins/grin.gif
  11. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    We use this powder stuff at work to clean the concrete shop floors. You put the powder down and spray the floor with water, then scrub it. Ill see what its called today when I go in and let you know. I think Malco makes it.
    UPDATE* Upon some research while sittin here in physics class I found the website with stuff. /forums/images/graemlins/grin.gif
    Concrete/Floor Cleaner/Degreaser
    Heavy Duty Cleaner
    Im not sure which one we use exactly though.
  12. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    I have always used Tide, Gas or solvent,and water. Pour gas/solvent on the bad oil stains and work it in with a stiff push broom
    let it set for a while then wet it all down and pour Tide detergent all over the drive way and scrub it down good with the stiff push broom. Wash it off
    Works great /forums/images/graemlins/thumb.gif
  13. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    I vote for the castrol superclean, it's some mean stuff.
    -Jeremy
  14. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Get a bottle of CLR (Calcium, Lime, Rust). It removes rust stains before your eyes. /forums/images/graemlins/thumb.gif It's with the bathroom and sink cleaners at the department or grocery store. /forums/images/graemlins/cool.gif
  15. MEPR
    MEPR 1/2 ton status
    Oct 21, 2002
    1,546
    McChord AFB
    Try a can of Coca-Cola, it realy does lift grease stains, just pour some on there and let it sit for a while then just whipe it up and it should be perty clean.
  16. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    I bought some stuff called Greased Lightning to clean the gunk off of my 14 bolt. It worked like a champ. I left the bottle in the driveway and ran it over /forums/images/graemlins/blush.gif.... it gave up the ghost and everywhere it spilled was nice and clean.
  17. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    greased lightning. . . isn't that what you pour in your gas to clean your engine?
  18. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    gas doesn't work on oil though- it'll run right off, oil is made to resist gasoline.
  19. K5thatShmobs
    Sep 27, 2001
    353
    San Luis Obispo, CA
    Ive tried the Castrol Superclean stuff... didnt do much actually. Dims the spots a little and gets rid of the grease, but you can definitely still see a pretty dark spot.
  20. BigOrange90Jimmy
    BigOrange90Jimmy 1/2 ton status Premium Member
    May 24, 2002
    2,923
    Wilmington, NC
    Get some Purple Stuff. It works wonders around here. I'm not joking either, that's really the name of it.
