Time for a lift what is everyone here running?
Discussion in 'The Garage' started by k5-newbie, Oct 5, 2004.
  1. k5-newbie
    k5-newbie 1/2 ton status
    Jun 19, 2004
    399
    Huntsville, Texas
    I have an '82 K5 that I have swapped in a TBI 350 and the 89 front grill...now its time to lift it. I was looking at a Tuff Country 6" but I can go 2 ways with this particular lift. I can go with 6" lift springs or a 4" shackle flip and 2" springs for the rear.
    Which way would you guys go and would you order it from ORD or somewhere else?? Or would you go with a different lift all together?
    Thanks in advance,
    Ben
  2. Topdown
    Topdown 1/2 ton status
    Nov 26, 2002
    2,598
    Vancouver, Washington, U.S.A
    Tuff country all spring lift.
    I am personally not a fan of the shackle flip unless you replace the springs AND do the flip. Yes, its cheaper but TC matches their springs (front to rear) and I dont know about your truck, but my stock springs were not in the best of shape (I.e. sagging, soft, crappy to begin with)
    Just my .02
  3. smokkey1
    smokkey1 1/2 ton status
    Jan 7, 2004
    2,677
    Los Angeles, CA
    I was in the same boat as you at first. but I decided to go with the 4" tc springs up front and the 4" shackle flip out back. the 36's clear but any little bump the tire would hi the fenders. the reason I went with 4" lift is that I woudln't have to mess with the drive shafts and to have a lower center of gravity.
    that's with 4" and 36"
    http://community.webshots.com/photo/124356291/128185514MXXlJT
    and after I cut the fenders I probabley can fit 38" now
    http://community.webshots.com/photo/132957664/149697021ZYmSVz
  4. k5-newbie
    Jun 19, 2004
    399
    Huntsville, Texas
    The shackle flip was gonna be a 4" shackle flip with new 2" springs from Tuff Country, then 6" springs up front. But I was thinking about just going with springs all the way around.
  5. mtnman210
    mtnman210 1/2 ton status
    May 30, 2003
    3,880
    Northridge, Ca
    6in pro comp springs in front and back and also a 2in tapered block in the rear
  6. jekquistk5
    jekquistk5 Weld nekid Premium Member GMOTM Winner
    Jan 18, 2004
    11,008
    841
    Pinckney, MI
    Im running TC 6" springs in the front, and a 6" block in the rear, yah i know about the block thing, but im goign to be doing a shackle flip and 2" TC springs as soon as i get the 14bolt and d60 home! /forums/images/graemlins/peace.gif
  7. firefighter184
    firefighter184 1/2 ton status
    Apr 5, 2003
    2,763
    The Barrio
    TC 3inch front 4inch rears. Running 33's now, but with minor trimming, I'll be able to fit 35's no problem. VERY happy with the TC springs. Get it all from ORD, whichever way you decide to go.
  8. k5-newbie
    Jun 19, 2004
    399
    Huntsville, Texas
    the reason im going 6" is I want to run 39.5 boggers. I figure I may have to trim some.
  9. djsblaze
    djsblaze 1/2 ton status
    Jul 7, 2003
    318
    Oklahoma
    I run 6 inch Rancho springs in front, Flip and 2 inch Ranchos out back. Mines stiff, go BDS or TC. I like the shackle flip. With my D60s it sits more like 7, 7.5. I run 38 inch tires with some rubbing at FULL stuff, but I also have the bushwhacker cutouts (dont buy the cut out flares, just trim the metal on yours). The cutouts will snag every tree in sight, and are not that durable. Good luck.
  10. rcurrier44
    rcurrier44 1/2 ton status
    Oct 13, 2003
    320
    39" boggers...you are realy looking to wheel this thing then /forums/images/graemlins/cool.gif
    If I were you I would run some 2" lift rear 52" TC's in front(if TC is what you like) and 2" 56" TC's in the rear with a shackle flip (might have to swap sides or drill out new holes for the rear flip).
  11. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    Nice rig. What is that on the drivers side rear?
  12. smokkey1
    Jan 7, 2004
    2,677
    Los Angeles, CA
    thanks, storage box.
  13. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    6IN BDS spring w/zero rate in front, 4in bds springs in back with zero rate and 2 1/2 in shakle flip
  14. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    That's what I did...
    2" TCI/ORD shackle flip in the rear...
    6" TCI front...
    The only problem is rear height...
    since a shackle flip is actually only 3 1/2" of lift...
    the rear was sitting about an inch lower than the front..
    I was going to make longer rear shackles...
    but when I moved my front end forward 2"s...
    I lost about an inch...because I re-located the shackles up front.
  15. k5-newbie
    Jun 19, 2004
    399
    Huntsville, Texas
    yes, soon it will be strictly trail, I have a D60 and 14FF on the way also, I have done a lot of work so far and still have not been wheeling /forums/images/graemlins/angryfire.gif (too busy at work), but soon!!!!
  16. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Well then its going to get dinged up and never be restored , you may as well just go 4 inch springs and the shackle flip , have plenty of flex , and /forums/images/graemlins/hack.gif the fenders for what ever tires you want /forums/images/graemlins/waytogo.gif
  17. k5-newbie
    Jun 19, 2004
    399
    Huntsville, Texas
    I have probably restored it more than I ever should have. I bought it to go beat on it and ended up really liking the truck and putting more time and money into it than I should have /forums/images/graemlins/histerical.gif
  18. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    4" BDS all spring, 2" PA body lift.
  19. wasted wages
    wasted wages 3/4 ton status
    Dec 3, 2003
    9,194
    Dallas Texas
    8" all spring lift (skyjacker) /forums/images/graemlins/thumb.gif
  20. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Superlift springs up front, flip in the rear.
    Soon to be running 52s/63s
