Time for a new Master Cylinder - part number for 1 Ton model?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BurbinOR, Sep 16, 2001.
  1. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    My '79 original 1/2 ton master cylinder is ready for a replacement..........and I have a Dana 60/14BFF combo (with the drum brakes). Two questions -
    1. Will the one ton MC bolt right on?
    2. Does anyone know what the part number is for the 1 ton MC, or maybe better, what year K30 to buy for?
    Thanks in advance.
    <font color=blue>'79 ONE TON TPI K5 - See it at---&gt;<a target="_blank" href=http://www.blazzinor.rockcrawler.com>www.blazzinor.rockcrawler.com</a>
  2. moneypit
    moneypit 1/2 ton status
    Sep 3, 2000
    1,382
    COLORADO
    I tried the 1 ton and it would not work. Let me know if you find 1 that does and post the part # for everyone else. Thanks and good luck!
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I'm fairly sure all 1 tons had hydroboost. All of the ones I've ever seen have had it.
    Tim
  4. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    I got a 3/4 model MC from Autozone. I'm not sure if it's really any different from a 1/2, but it bolted right up.
    -- Mike
    <font color=blue> At some point I'll be done building my truck and can actually go wheeling. Until then, I guess sex and alcohol will have to do. [​IMG]
  5. prjt_blzr
    prjt_blzr 1/2 ton status
    Mar 4, 2001
    352
    COS, CO
    I have put a K30 MC on my K5 and it bolted right up. There are two styles if I remember correctly. You need the 1.25" bore and the shortinput cup. The other style is a 1 5/16" bore with a long cup. I got mine from napa by asking for a MC from an 80s K30 without hydroboost.
    I don't know how well this works yet as the truck is not yet mobile.
  6. BurbinOR
    5,829
    Oregon
    To the top, gotta be someone that has tried/done this without swapping the booster.
  7. dyeager535
    26,975
    The only difference I know of between MC's (1/2 ton only experience, but GM, should carry across the line you'd hope) is the bore. You can not fit a big bore MC on a booster made for the "small bore" MC. You can pull the MC off without cracking the lines IIRC, so its not like it would be tough to unbolt the MC from the booster, and measure/inspect the "pocket"
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>http://www.dorianyeager.com/index2.html</a>
    No anti-theft measures on your truck? No pity when its stolen
  8. BurbinOR
    5,829
    Oregon
    Thanks Dorian. Anyone actually done this?
