time for more lift!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by MUD JUNKIE, Apr 12, 2003.
  1. MUD JUNKIE
    MUD JUNKIE 1/2 ton status
    Oct 24, 2001
    379
    Reddick,florida
    I'm thinking on going with a 6" suspension lift and getting rid of my 4" I can fit 38" tires without rubbing with my current setup (4"+3") and would like to set up to at least 39"s
    I found someone with 6" springs for sale and rear springs also,no hardware,just the springs for 250$$what else would I need? I have a 79' chevy pickup
  2. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    driveshafts probably need lengthened with that much lift and steering correction, brake lines if you dont have already
  3. MUD JUNKIE
    Oct 24, 2001
    379
    Reddick,florida
    ok the brake lines for sure,what would I use for the sterring? I already have the drop drag link,I use the raised arm or the block correct?
    what about the front axle angle? would it be to steep with a CV driveshaft?
  4. BamBamblazer
    BamBamblazer 1/2 ton status
    Jun 24, 2002
    486
    McCordsville, Indiana
    I have a 6" lift and my front shaft has been fine so far. My rear shaft was lengthened but i still had a vibe /forums/images/graemlins/mad.gif, so i replaced it with a c/v shaft from hi-angle and no more vibes. /forums/images/graemlins/thumb.gif I think if you have a drop draglink that will be enough correction on the steering. I hope this helps you and if you have anymore questions i'll try to help.
  5. jekbrown
    May 19, 2001
    45,030
    362
    Vancouver, WA, USA
    fender trim, you can get 39.5s to fit. Mine fit np and I only have 1" of body lift and about 5" of susp lift.
    j
  6. MUD JUNKIE
    Oct 24, 2001
    379
    Reddick,florida
    I have no problem with trimming but theres alot of deep water holes that put me under,and I need that little bit more lift to finally defeat that deep mudhole.I know that with 2 more inches of lift and 39" tires that will put me up alittle more so thats cool.
    I've got a pickup thats a long bed,do you still think that I will have vibes? how much does it cost to lengthen a shaft?
  7. jekbrown
    May 19, 2001
    45,030
    362
    Vancouver, WA, USA
    snorkle?
    j
