Time to check in, whats everyone working on?
Discussion in 'The Garage' started by uglychevyZZ4, May 1, 2004.
  1. uglychevyZZ4
    uglychevyZZ4 3/4 ton status
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    Havent posted this in a while so lets hear it, current rig projects? Mine are decidely moving forward.
    -We scrapped the MOG AXLE swap for a later date since our new house needed new vinyl windows which are $ 3800.00 and the axles were 4000.00, see the equasion /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif oh well, next summer maybe unless I find a better deal.
    -got all my FI swap stuff a while back, got a hell of a deal off ebay in a chat room, some seller got hosed on a payment and needed money fast /forums/images/graemlins/wink.gif*BLING* he got it, 120.00 shipped for EVERYTHING to do the swap.
    -springs getting swapped out for longer ones.
    -going truggy of course, using a stock front clip but removing 12 inches from the center so it still looks like a chevy /forums/images/graemlins/peace.gif
    -just got some 39.5's for it
    - now looking for a d60 /forums/images/graemlins/rolleyes.gif
    -ripping out the 383 when i do the truggy work to rebuild it.
    Thats all i can think of for now, enough for the next 3 months to do while working on our new house.
  2. bigyellowjimmy
    bigyellowjimmy 1/2 ton status
    Jan 15, 2004
    2,105
    Chandler, AZ
    Just finished putting long travel shocks up front, need to trim the front fenders more next and replace a front axle shaft. /forums/images/graemlins/thumb.gif
  3. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    Roll cage, top chop, and sub frame
  4. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    Finding a job,,,
    so i can start a project. /forums/images/graemlins/thumb.gif
  5. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    Saving my moola /forums/images/graemlins/doah.gif
  6. ben427
    ben427 1/2 ton status
    Mar 10, 2002
    1,123
    Waverley, Nova Scotia
    Gettin ready to take the cab off the cucv so i can gear up the doubler easier as well as put the engine etc in. Gonna sandblast the frame and epoxy it while the cab is off, as well as shorten the frame if doubler permits.
  7. Desert Rat
    Desert Rat Fetch the comfy chair
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    1976 Blazer w/ 350/TH350/NP205/GV OD
    Front TC 6 inch springs just installed w/ ORD greasable shackles. Rear TC 2 inch springs w/ greasable shackles.
    Front D60 nearly complete with POR-15, ARB Air Locker, 4.56 ring and pinion, Crane High Clearance cover, new bearings, new u-joints, Dedenbear knuckles, ORD crossover arm, new calipers, ORD HD tie rod, and crossover arm, new rotors, HD Warn hubs, and SS brake lines.
    PSC (Former AGR owner) steering box and HD pump being installed now.
    Rear Corp14ff POR-15'ed , new bearings, 4.56 ring and pinion, Detroit Locker, w/ disk conversion using AZ-Kickin brackets and SS brake line setup, new rotors, TSM Caddy calipers and Superior 4340 Chromoly axles completed awaiting install.
    4x4Iron rear tire carrier bumper and front square tube bumper ordered and awaiting arrival. Warn 9.5 Ti winch ordered awaiting arrival.
    Goodyear MT-R's awaiting purchase on 16x10 Rockcrawlers
    43 gallon PNWMP gas tank awaiting removal of rear tanke and installation of ORD shackle reversal.
    New shocks all around, most likely Rancho adjustables.
  8. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    -body lift (just got the longer bolts)
    -get gas tank back in
    -get the truck started and do a tune up
    -start main hoop of cage, seat bases and harnesses
    -rear storage
    -echibit flip, longer shackles and 1/2ton 56" springs, inboarded shock setup/gabrials, swap in 14BFF/5.13/welded
    -4" springs up front, longer shackles, Ford towers/gabrials, swap in 10bolt/5.13/minispool
    -pickup tailgate
    -paint outside Orange or Metallic Copper
    -Paint the inside grey or tan (instead of black)
  9. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    Get the K5 painted PPG black cherry
    Redo entire interior with new seats, all black material, 3D flames, and auto meter guages
    Chrome my 10 shocks and lift blocks.
    Powder coat my skid plates, stabilizer bar, steering components red.
    Call it finished! /forums/images/graemlins/peace.gif
  10. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    Just finished the 1 TON swap. Waiting on JC Whitney to send me the right springs this time so I can put in the 57's. Just need to put on the F*rd shock towers and fab a rear upper shock mount...other than that, I think I'm done until I ight add some tube doors and a soft top (if there isn't a big hole in it /forums/images/graemlins/ignore.gif )
  11. txfireman110
    txfireman110 1/2 ton status
    Nov 1, 2003
    294
    San Angelo, TX
    Started Thursday (finally):
    81-up front clip
    454/TH400/NP205
    D60/14bff(with discs)
    crossover
    hydro assist
    38.5x14.50TSL/SX
    black steelies
    GET RID OF ROUGH COUNTRY CR*P!
    Ford towers/long shocks
    POSSIBLE full top /forums/images/graemlins/hack.gif /forums/images/graemlins/grind.gif /forums/images/graemlins/weld.gifif I get the b*!!s
  12. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Hydraulic clutch setup, rear shackle flip, 14 bolt install, and figuring out fuel system(stock tank or fuel cell in bed?). Shouldn't be long at all.
  13. Esteban86K5
    Esteban86K5 1/2 ton status
    3,712
    Bakersfield, CA
    I am currently working on my flat belly skid plate. Will be installing disk brakes in the rear this weekend and installing my front locker early next week. Oh and I ned to redo my exhaust so it's tucked up above the frame rails. All this needs to be done by Thursday so I can go to the Hammers on Friday!! /forums/images/graemlins/woot.gif
  14. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    Im just working on keeping my truck running. and saving up for gas.
  15. justhorsinaround
    justhorsinaround 3/4 ton status
    Sep 16, 2003
    6,798
    Northerish Phoenix, Az
    Well I'll be replacing a window in my son's room that he threw a toy through. Yes through. By the way he's 2 and a 1/2.
    He'll be learning how to pitch later this weekend so he can be the youngest major league hurler ever. /forums/images/graemlins/whistling.gif
    Good luck to y'all in the future.
    Allan
  16. big pappa b
    Jan 3, 2003
    6,328
    Falcon, Colorado
    and almost forgot, as soonas my D60 DEE-troit locker gets here I will be installing it along with the 35 spline outers and warn premium hubs...Hopefully all this won't be under too much stress by these HUGE 35's I have /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif
  17. uglychevyZZ4
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    /forums/images/graemlins/confused.gif whats that mean?
  18. uglychevyZZ4
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    [/ QUOTE ] /forums/images/graemlins/blush.gif /forums/images/graemlins/yikes.gif
  19. Mastiff
    Mastiff 1/2 ton status Premium Member
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    Just finished installing longer rubber brake lines to get rid of the factory ones + drop bracket that came with the Rancho lift. Had to put new steel lines in too. Trying to eliminate a leak at the prop valve and get all the air out. /forums/images/graemlins/mad.gif
    Took the inner fender out on the passenger side to help get the brake lines in easier, also battery tray. Since they're out, I'm gonna get the rust and old paint off and redo with POR-15. /forums/images/graemlins/thumb.gif
    Still waiting on my EFI upgrade kit from customefis.com. It's been 3-4 months or something since I ordered. I do NOT recommend dealing with that guy unless you are extremely patient. /forums/images/graemlins/mad.gif
    The other summer project is to gut out all the blue interior and replace with black to match my new yellow paint job. /forums/images/graemlins/cool.gif
  20. mudjunkie 82
    mudjunkie 82 1 ton status GMOTM Winner
    Dec 27, 2002
    11,449
    Cleveland Ohio
    [​IMG] /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/truck.gif
