Time to cut some sheetmetal
Discussion in 'The Garage' started by rockink5, Jul 7, 2002.
  1. rockink5
    rockink5 1/2 ton status
    Feb 6, 2002
    693
    Tracy, CA
    Well it's time to trim some sheetmetal. I know a few guy's here have done it ( and had it turn out good) Does any one have some pics? also what did you use to do the cutting. Thanks /forums/images/icons/smile.gif
  2. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    Ummm...did you try a search? It's been discussed a million times. /forums/images/icons/grin.gif
  3. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    One tip that you may not fine in your search is my special cardboard technique to get both fenders to turn out the same. I cut out a piece of cardboard with the same contour as the 1st fender I trimmed, then lined it up on the un cut side and spray painted the area I needed to cut. That way its somewhat symmetrical on both sides.
  4. rockink5
    Feb 6, 2002
    693
    Tracy, CA
    Thats the stuff im looking for . Not " I took a sawzall to my fenders today" I had not thought of the pattern, Thanks
  5. efilnikufecin
    efilnikufecin 1/2 ton status
    Feb 27, 2002
    168
    flint,mi
    depending on how much you want to cut?i got mine hogged out pretty good.i used a cut off wheel.makes smoother cut than a saws all.use masking tape to mark out your cut line.here's my page.
    http://community.webshots.com/user/efilnikufecin
