Time to pull the engine again
Discussion in 'Other Rides' started by chvyhs, Feb 16, 2002.
  1. chvyhs
    chvyhs 1/2 ton status
    Feb 12, 2001
    1,469
    Murrieta, California
    I just changed the headgaskets, put studs for the oil pan, and put a new oil pan gasket. Now I have a knocking sound from the lower end. I don't know what's going on with this thing. First everything was running real well, then I noticed oil pressure was reading around 65lbs from idle to 6000 rpm. Then came the knock. First it was a tick, so I re-adjusted the rocker arms (solid lifer cam). That wasn't it so I changed the oil filter and checked the oil bypass spring. They're fine. So now I'm pulling the engine again so I can inspect the crank. It never ends. Atleast I can count on the Suburban to get me home. By the way it's a Big Block 396 set up for the drags if you have any ideas to what the problem is.
    <a target="_blank" href=http://community.webshots.com/user/chvyhs>WebShot Pics</a>
    It's a wheelbase thing, you wouldn't understand.
  2. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    If your oil press doesnt change during the rpm band then something is wrong in the oiling system, like plugged oil galleys or some thing. At the track my Firebird has around 40 at idle, and going down the track it goes above 100 psi. On the street cruising it has around 45-50 psi.
    86Jimmy 4"&35"MTRs,87 burb 4"&33"MT,69Firebird w/525 hp,and 70GTO live in PHX,AZ<a target="_blank" href=http://www.geocities.com/modifierperformance>My vehicles</a>
  3. chvyhs
    Feb 12, 2001
    1,469
    I have glitter in the bottom of my oil pan. It looks like the crank is comming out next.
  4. chvyhs
    Feb 12, 2001
    1,469
    All of the main bearings are spun. Doesn't look like the crank is damaged too bad. I also pulled the #4 rod bearing, it's spun too.
