Timing, 6 degrees alright?
Discussion in 'The Garage' started by sled_dog, Apr 1, 2003.
  1. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Factory specs are for 4 degrees before on the 305 that was in my truck, I replaced it with a 350 and set my timing today to about 6 degrees before. I had been running it for about 2 weeks at about 10 degrees before. Seems smoother at higher Rs. Should I take the time and set it back to 4 degrees or what?
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    If it runs good with 6 degrees leave it. It is about middle of the road timing wise. It isn't high, and it isn't too low. You can try and advance it a little and see how it does, but personally if it runs fine then leave it alone.
  3. Topdown
    Topdown 1/2 ton status
    Nov 26, 2002
    2,598
    Vancouver, Washington, U.S.A
    according to the 1972 manual that I have... for a stick it should be at 4 and an auto should be at 8.
    -Ryan
