timing a 350 sb
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by CAROLINAK5, Aug 5, 2001.
  1. CAROLINAK5
    CAROLINAK5 1/2 ton status
    Aug 2, 2001
    242
    lexington, north carolina
    missing the emission sticker under the hood and need some info to set timing....
    350 with holley 600 carb (model 4160)
    what RPM to set at?
    what to set the timing at?
    do i have to plug any vacuum lines at the carb?
    any help would be appreciated.
    thanks!
    QUESTION: Yellow Jeep?
    ANSWER: Speed Bump!!!!!!!
  2. soba
    soba Registered Member
    Jul 19, 2001
    13
    Austin, Tx
    I think about 8degrees btdc @ 550-600 rpm depending on your trans , manual or automatic. Just disconnect the advance vaccum from fhe carb , and plug both ends while setting the timiing check out this site http://www.centuryperformance.com/timing.htm has a nice explanation on timing.
    78 bronco- 351M . C6 , Dana44, 9 inch, np205 32s 67 camaro - stock I-6 250ci :(
  3. soba
    Jul 19, 2001
    13
    Austin, Tx
    oh yeah if your not running a stock cam then you will have to advance the timing a bit depending on your cam duration
  4. 4x4blazer
    4x4blazer 1/2 ton status
    Jun 14, 2000
    278
    Louisiana
    <a target="_blank" href=http://www.centuryperformance.com/timing.htm>http://www.centuryperformance.com/timing.htm</a>
