Timing Adjustment Question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by caryhenry, Oct 3, 2002.
  1. caryhenry
    caryhenry Registered Member
    Sep 28, 2002
    78
    Tallahassee, Fl
    Alright guys, I can't tell which bolt is the distributor hold down bolt. I need to retard my timing a lil' and I need to loosen the distributor. It's an 85 blazer with a 305. Please help me out and tell me which bolt to attack...Thanks!
  2. or2play
    or2play 1/2 ton status
    Feb 22, 2002
    657
    Yuma, Arizona
    There is a 9/16 bolt that screws into the intake. Its probably under your vacuum advance canister or pretty close to it. You can get a special "distributor wrench" from sears that makes it alot easier to get in there and loosen it.
  3. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,073
    486
    Grand Rapids area
    Look at where the distributor shaft goes down into the engine. There is a little fork-looking thing shaped kind of like a "Y" that is holding the distributor down. The bolt is in that. It is behind the carb, in front of the vacuum advance cansiter, underneath the distributor, passenger's side.
