Timing advance questions
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Lazydog, Dec 13, 2002.
  1. Lazydog
    Lazydog 1/2 ton status
    Apr 17, 2002
    129
    Phoenix, Arizona
    I was just wondering if I need to modify the rate at which the advance comes in. The power band on my Jimmy seems to go "flat" around 2500 RPM. I was wondering if recurving the distributor would help? I am wondering if maybe headers would help to? I am running the original manifolds and single exhaust. I rebuilt the engine 2 years ago.
  2. 4x4Freak
    4x4Freak 1/2 ton status
    Apr 21, 2002
    792
    Lubbock, TX
    Headers and a decent exhaust system would probably help quite a bit. At higher rpms they would help the engine get rid of the exhaust better than the stock manifolds.
    Recurving the dist. might help too, make sure the mechanical advance is not frozen up to start with.
  3. tRustyK5
    Jul 23, 2000
    36,173
    1,384
    E-town baby!
    I found the mechanical advance on my old 350 was all gummed up and not working at all. 15 minutes to disassemble and clean and the difference in performance and drivability was impressive! My vacuum advance was also not working...that cost about $14 to replace. I'd check that first before trying to re-curve.
    Rene
  4. Lazydog
    Apr 17, 2002
    129
    Phoenix, Arizona
    Your right, I should check to see if I'm getting any advance at all. I didn't rebuild the distributor when I did the motor. I also converted it from Automatic to Manual trans.
  5. SCOTTS_4X
    SCOTTS_4X 1/2 ton status
    Mar 22, 2002
    129
    Modesto CA
    get yourself a re-curve kit before you take the thing apart. while you have the cap off compare the springs in the kit to the springs you have on the counterweights in there. if the ones you are running are way stiffer go ahead and switch them out. there's nothign wrong with a quick advance. my dad is a mechaninc and has several mechanic friends and I have always been told by them to run the lightes springs in the kit. also from an advance point of veiw, I was also told to take the stock advance and throw it out the window. if it runs best at 8* then run it there, if it runs best at 40*, run it there.
    -Scott
