timing advance
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by lasvegas, Dec 30, 2001.
  1. lasvegas
    lasvegas 1/2 ton status
    Feb 27, 2001
    122
    Las Vegas, Nevada
    What is good advance for '01 zz4 crate motor w/ HEI? I was thinking 8 to 12 BTDC? Anyone know?
  2. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    You can start anywhere in that range, more likely try 6* to start to get that beautiful new motor started and broken in. Then you can play with the base timing, vac advance (maybe put in an adjustable one), recurve the mechanical advance, etc. Lot depends on what gas you are running (octane rating), aluminum heads (not sure if ZZ4 has them or Vortecs), etc. Start mild for the breakin and then start playing.
    <font color=blue>'79 ONE TON TPI K5 - See it at---&gt;<a target="_blank" href=http://www.blazzinor.rockcrawler.com>www.blazzinor.rockcrawler.com</a>
