Timing after rebuild
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Rocky91, Aug 7, 2002.
  1. Rocky91
    Rocky91 Registered Member
    Feb 14, 2001
    44
    Rochester, NY
    I just finished rebuilding my '91 TBI 350. It started on the first try and sounded good. When I checked the timing it was 12 degrees BTDC. What should the timing be for this engine? I set it to 4 degrees BTDC but when I drove it, it didn't have any power. Thanks.
  2. Mr.Chevy4x4
    Mr.Chevy4x4 1/2 ton status
    Jun 16, 2000
    1,932
    Sims, NC
    It is important to remember that there is a brown with white stripe(IIRC or it might be purple) wire over by the fuse block that has to be disconnected to correctly set the timing. It will emerge from the wire loom shielding and it will have a male and female type connector on it. Just unplug it and set your timing, then plug it back together.
    Hope this helps!
    Mike
  3. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    Set it to 0 degrees with the wire unplugged. The computer will automatically advance it when you plug that tan wire with the black stripe back in. Make sure to do all the plugging and unplugging with the engine off.
  4. wheelin72
    wheelin72 Registered Member
    Mar 6, 2002
    97
    Hanford, CA
    so on TBIs all the timing is automatic?
  5. Blazer_Boy
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    In the words of Hank Hill, "Mmmmhmm, yep".
  6. Rocky91
    Feb 14, 2001
    44
    Rochester, NY
    Thanks for the help. I couldn't find the wire, I'll try again in the morning.
