timing chain noise
Discussion in 'The Garage' started by bigbadchev84, Jan 31, 2005.
  1. bigbadchev84
    bigbadchev84 1/2 ton status
    May 17, 2004
    2,191
    Hermiston, Oregon
    I just got done installing a newer 350 into my blazer, it was in alot better shape than my previous 350 and ran great in the truck i pulled it out of, all i did was clean it up, re-gasket everything except the head gaskets, and i replaced the timing chain, no big deal ive done this i dont know how many times. i get the thing all done get it to fire up and about a minute after running it started squeling really loud, i checked the belts and ended up pulling them off and the noise is coming from the timing chain cover, i am planning on pulling it apart tonight, is there anything i should look for?
  2. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Was the balancer fully home? If it wasn't it may have let the lower sprocket move out towards the cover and let it rub.:dunno:
  3. bigbadchev84
    May 17, 2004
    2,191
    Hermiston, Oregon
    That may be it, because at lower rpm the crank pully looks like it was bent just a little bit but at higher rpm the noise goes away and the balancer straightens out, i will see if i can tighten it a little more, thanks
