"Timing chatter"
Discussion in 'The Garage' started by chief77, Mar 7, 2005.
  1. chief77
    chief77 Registered Member
    Mar 4, 2005
    14
    Alabama
    I just recently noticed when "ole gal" idles the timing chain chatters, does anyone know if this is a common effect, or should I look into it?
    77 K5 with new GM Performance 290hp crate.
    New oil and filter 10/30 Castrol, Fram performance filter.
    thanx: chief77 :k5: :usaflag:
  2. chief77
    Mar 4, 2005
    14
    Alabama
    [[[bump]]]] come on guys, has anyone got an idea on this..... :1zhelp: :1zhelp: :1zhelp: chief77 :k5: :usaflag:
  3. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    I've never heard a chain chatter before.
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Hook up a timing light and see if the timing mark appears to be jumping around at idle. If so, then it's time to replace the timing chain and gears.
  5. zeroz400
    zeroz400 1/2 ton status
    May 30, 2004
    410
    Libertyville, IL
    You can see if your chain has slop by getting #1 at TDC, then take your distributor cap off and rotate your crank. If your rotor doesnt move and your wrench goes more then about 8degrees then you probably have to much slop in your timing chain.
    Later
