Timing\Fuel Problem?
Discussion in 'The Garage' started by 2High4U, Aug 24, 2005.
  1. 2High4U
    2High4U 1/2 ton status
    Aug 20, 2005
    542
    Felton Pennsylvania
    I just bought a 73 Blazer 1 month ago and I couldnt drive it because the tranny was shot... so i put a rebuilt TH350 in it and went to drive it it seems to run good no unusual sound but I have no power on hills and after driving it for a while it back fires through the carb I adjusted the timing to 12* and set the new edelbrock carb to its factory settings 2 turns the idle adjustment is all the way down and it seems to idle too high and when i put it in gear it goes in a little hard or rough but not painfully hard oh and there is a electric fuel pump connected to the mechanical one for some reason too. any ideas im thinking it may be the timing chain or something. i have to have it running good because I have to drive it to pennsylvania 3000 miles away from here
  2. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    Hmmm adjust the points or why even do that replace with an HEI
  3. 2High4U
    Aug 20, 2005
    542
    Felton Pennsylvania
    I forgot to mention that it has an hei distributor :thinking: i replaced the cap rotor and wires where should the timing be?
  4. uglytruck
    uglytruck Registered Member
    May 9, 2005
    27
    Phoenix, Az
    How many miles does your engine have, as it may very well have a stretched out timing chain, although I'm not sure that would throw your timing that far off. I had an old cutlass that ran OK until it quit on me, turn s out the timing chain jumped. New timing chain produced a much better running engine than before. So if it has high miles it can only help to change, good luck.
  5. kawijames
    kawijames Registered Member
    Aug 14, 2005
    8
    texas
    re :missing power
    I'm new to the board but have been doing gm performance for some time now maybe i can help. 1st what kind of edelbrock are you running? do you know the specifics of the motor(ie comp ratio,cam size etc)? on my last burban i dropped down to a 600 cfm to get more response but only to lose ALOT of power, the main jets were just too small. also when you turn the key does is spint the motor a few times and then start or does it just fire right up on the first time? other possibilities are : substandard plugs and wires, old coil loosing output ability, timing could be off, needle seats sticking in the carb( common w/ edelbrocks that are up in age). when was the last time the truck got a Proper tune up? ya know sometimes the small things we overlook are the ones that cause the most grief!
  6. diesel4me
    Jul 24, 2003
    17,583
    945
    Massachussetts
    HEI hooked up right??
    If whoever put the HEI in didn't run a new 10 ga wire from the fuse box to power it,and used the original "hot" wire to the old coil to power it,that might be the whole problem..you need a full 12 volts ,and the old coil wire is a resistance wire that reduces amperage to avoid burning the points out quickly--wont deliver enough voltage for an HEI distributor..I've bought a few trucks cheap because of that,and lost count as to how many I had to re-wire at my friends shop that had HEI transplanted into older trucks..
    I'd probably want a new timing chain if I had a 3000 mile ride ahead of me!--nearly every chevy V8 I've owned needed one,most had that crap nylon toothed camshaft gear that always loses its teeth, and most of the time they end up in the oil pump! :eek1: ..the timing chain and fuel pumps are the main failures in most chevy's towed into a shop during a long trip(like a vacation!)..
    May times Edelbrock carbs cant be "idled down" because of a vacuum leak--that can cause hesitation and backfiring too...spray carb cleaner at any gaskets or hoses you suspect might be letting air sneak in--it will change the rpms while its idling if you spray it on a leaking area.. :crazy:
  7. 2High4U
    Aug 20, 2005
    542
    Felton Pennsylvania
    The engine probably has alot of miles but im not exactly sure how many, the engine seems to be stock except for the carb and intake I did a tune up on it plugs wires cap rotor gaskets hoses-etc and its not hard to start takes about3-5 seconds ill check for vacume leaks check wiring and replace timing chain thanks for all of your help ill get back to you guys and let you know what happens.
  8. blazinzuk
    Dec 20, 2002
    17,412
    3,799
    Yah if the HEI wasn't put in right that could contribute to the problem. I kind of am leaning towards the distrubitor did you check the module and stuff. No power under load also may be the fuel pump or something in your carb. I have never seen a timing chain skip a tooth or anything like that (not saying it can't happen) but I did install one wrong once and it didn't run right at all
  9. 2High4U
    Aug 20, 2005
    542
    Felton Pennsylvania
    I checked the wire from the distributor it is what i believe to be the same size as the ignition wires inside but goes to a smaller wire on the firewall then into the place behind the fuse block would that be causing the problem or contribute to the problems? the electric fuel pump works fine and one thing that stumps me is that when im on level surfaces its ok only when im on bigger hills it looses power some one told me that it could be dirty gas or have water in it this is really frustrating especially having to be out of my place at the end of the month if i can make it through death valley\mountain passes ill be ok
  10. kawijames
    Aug 14, 2005
    8
    texas
    have you checked your needle seats yet? with the edelbrocks there are no gaskets below the fuel line so it takes out a gaskety on the carb problem.i had a problem like yours with 2 edelbrocks back to back( maybe a manufacturing problem on that batch?) also with the back firing that definitely sounds like a timing problem to me. have you tried advancing and retarding the timing while the engine is running? its incredibly easy to get the dist a tooth off when you are reinstalling it. hope some of this helps.
  11. TongQiang
    TongQiang Newbie
    Aug 25, 2005
    China
    My proposal
    FROM THE DESK OF:
    MR.TONG QIANG,
    BANK OF OVERSEAS CHINESE
    TAIPEI,TAIWAN
    Dear Friend,
    How are you today and business in your country? I am
    Tong Qiang, Bank Manager of bank of Overseas,Taiwan. I
    would respectfully request that you keep the contents
    of this mail confidential and respect the integrity of
    the information you come by as a result of this mail.
    I contacted you independently of our investigation and
    no one is informed of this communication. I would like
    to intimate you with certain facts that I believe
    would be of interest to you. I know you would be
    wondering why I am writing you with a request such as
    this but I only urge you to read on.
    A British Oil consultant/contractor with the Chinese
    Solid Minerals Corporation, Mr.Courtney Steven made a
    numbered time (Fixed) Deposit for twelve calendar
    months, the Chinese Solid Minerals Corporation that
    Mr. Courtney Steven died from an airplane crash.The
    bank immediately launched an investigation into
    possible surviving next of kin to alert about the
    situation and also to come forward to claim his
    estate. If you are familiar with private banking
    affairs, those who patronize our services usually
    prefer anonymity, but also some levels of detachment
    from conventional processes. In his bio-data form, he
    listed no next of kin.
    In the field of private banking, opening an account
    with us means no one will know of its existence,
    accounts are rarely held under a name; depositors use
    numbers and codes to make the accounts anonymous. This
    bank also gives the choice to depositors of having
    their mail sent to them or held at the bank itself,
    ensuring that there are no traces of the account and
    as I said, rarely do they nominate next of kin.
    Private banking clients apart from not nominating next
    of kin also usually in most cases leave wills in our
    care, in this case; Mr. Courtney Steven died
    interstate. In line with our internal processes for
    account holders who have passed away, we instituted
    our own investigations in good faith to determine who
    should have right to claim the estate. This
    investigation has for the past months been unfruitful.
    We have scanned every continent and used our private
    investigation affiliate companies to get to the root
    of the problem.
    According to the Laws of Republic of China, at the
    expiration of 6 (Six) years, the money will revert to
    the ownership of the Chinese Government if nobody
    applies to claim the funds. What I wish to relate to
    you will smack of unethical practice but I want you to
    understand something. It is only an outsider to the
    banking world who finds the internal politics of the
    banking world aberrational. The world of banking
    especially is fraught with huge rewards for those who
    occupy certain offices and oversee certain
    portfolios,I alone have the deposit details and they
    will release the deposit to no one unless evidence of
    relationship with the deceased, which I shall provide
    you with, is presented. I alone know of the existence
    of this deposit for as far as Bank of Overseas is
    concerned, the bank's management has no single idea of
    what? the history or nature of the deposit. They are
    simply awaiting instructions to release the deposit to
    any party that comes forward.
    I am aware of the consequences of this proposal. I ask
    that if you find no interest in this project that you
    should discard this mail. I ask that you do not be
    vindictive and destructive. If my offer is of no
    appeal to you, delete this message and forget I ever
    contacted you. Do not destroy my career because you do
    not approve of my proposal,If you find yourself able
    to work with me, contact me through this email
    address. If you give me positive signals, I will
    initiate this process towards a conclusion. I wish to
    inform you that should you contact me via official
    channels; I will deny knowing you and about this
    project. I repeat, I do not want you contacting me
    through my official phone lines nor do I want you
    contacting me through my official email account.
    Contact me only through the numbers I will provide for
    you and also through this email address. My official
    lines are not secure lines as they are periodically
    monitored to assess our level of customer care in line
    with our Total Quality Management Policy. Please
    observe this instruction religiously. Please, again,
    note I am a family man, I have a wife and children. I
    send you this mail not without a measure of fear as to
    what the consequences may be, but I know within me
    that nothing ventured is nothing gained and that
    success and riches never come easy or on a platter of
    gold. This is the one truth I have learned from my
    private banking clients. Do not betray my confidence.
    If we can be of one accord, we should plan a meeting,
    soon.
    In closing, please observe utmost confidentiality, and
    be rest assured that this transaction would be most
    profitable for both of us because I shall require your
    assistance to invest my share in your country. Upon
    receiving your reply, I will then furnish you with a
    more comprehensive detail of this transaction and what
    is required of you.
    Awaiting your urgent reply.
    Yours Sincerely,
    Mr.Tong Qiang.
  12. 2High4U
    Aug 20, 2005
    542
    Felton Pennsylvania
    im not really sure where the timing should be i have it set at twelve degrees right now what should i advance it to 14? as for the carb it could be i have to fool with it and see what i can get out of it im going to turn them both 1
    \2 turn more i cant afford a new carb right now. with my job i dont have much time to work on it right now only on the weekends because im not allowed to work on it at my apartment complex :mad: i have to go to my inlaws house i really cant wait to get back to pa where i have spare rears tools and parts lying around i could use when i get settled in pa im gonna pay for a membership here because i like this site soooo much and by the way whats up with the dood from china :confused:
