Timing gun
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by therover87, Mar 21, 2002.
  1. therover87
    therover87 1/2 ton status
    Jun 24, 2001
    139
    Long Island, New York
    i am in the market for a timing light and i was wondering if it is worth the 220 for the Snap On on, or should i look at another company, what company do you guys use for this?, thanks
    I would rather push a chevy than drive a ford
  2. behemoth
    behemoth 1/2 ton status
    May 16, 2000
    1,833
    Northwest Florida
    I've got a cheapo Craftsman. It's worked just fine for more than 20 years now!
  3. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    220 bucks for a timing light? That is Way too much.
    I'v been using a Sunpro Light for years. Its been dropped. hit by a fans and burned by headers It still works great
    This is what I have:<a target="_blank" href=http://www.actron.com/cgi-bin/web_store.cgi?page=cp7519.htm&amp;cart_id=6447753_7396>Sunpro Advavce Analizer light</a>. $79.99
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    I've had my simple Craftsman timing light since around 1978 or so. I think it cost around $30 back then. It's done a LOT of tune ups and still works like a champ.
  5. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    A good quality timing light like the sunpro which I have is more that suffecient. Unless ya have to do timing on engines at shop all the time IE for a living then $220 is just out the window.
    Degree your damper in by finding TDC, or just set TDC on the mark and get a timing tape for $10.
    $40 and you have a reliable way to set up your timing.
  6. ChevBlazin
    ChevBlazin 1/2 ton status
    Feb 4, 2002
    332
    St. Paul area, Minnesota
    I think I'm using the same craftsman timing light my dad has had since before I was born, works just fine. Much cheaper too I imagine.
  7. weisel
    weisel 1/2 ton status
    Feb 22, 2001
    491
    Laveen, AZ
    All I have ever used is autozone chepo's and have never had any problems. There around 30-40 bucks I think.
    POWERMAD, what is a timing tape?
  8. TopOff
    TopOff 1/2 ton status
    Jan 16, 2002
    1,760
    Folsom, ca
    Either a dial back to zero timing light, or use a degree tape as PowerMad
    says.
    This way you can check initial timing, mechanical timing and vacuum timing.
    Good luck.
