Timing issues...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by reddog64, Dec 7, 2002.
  1. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    OK for the life of me I cannot get it to time correctly...
    Seems when I time it to 8 BTDC it almost dies, tthen at 8 BTDC if i give it gas and let go it dies... so i up the idle and it does the same thing.. if I back it off any, the timing it is way off the mark, and wants to diesel... if i adjust it, timing and idle, so it seems good it has NO POWER whatsoever...
    WTF... /forums/images/graemlins/angryfire.gif
  2. Doug M
    Doug M Registered Member
    Nov 8, 2002
    39
    Houston
    Stock 350? What has happened that has caused you to adjust the timing? And, are you setting initial with vac advance disconnected and plugged?
  3. reddog64
    Nov 9, 2000
    3,325
    i did set it initially with the vac advance disc and plugged.. set at 8 btdc.... and it runs like CRAP and doesnt stay running.....
    When I put it in gear, give it gas, and let off.. it dies....
    HELP!!!! /forums/images/graemlins/1zhelp.gif
  4. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> I'd use a piston stop to verify that the timing tab is at the right place. ALso, the outside ring can slip on harmonic dampers, mine turned about 45 degrees so now the mark is waaay off.</font color>
  5. reddog64
    Nov 9, 2000
    3,325
    so should I just tune it to ear...
    but why no power and hesitation when in gear and trying to go forward/backward....
    it revs in park/neutral just fine...
    /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/ears.gif
  6. 87sm465np208
    87sm465np208 1/2 ton status
    Aug 28, 2002
    1,114
    illinois
    when you put yur truck in D or R, you are putting a load on it. so it could be somthing with vacuum or a carb setting.
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/truck.gif
  7. reddog64
    Nov 9, 2000
    3,325
    hmmm how do i check my vac advance?
  8. Doug M
    Nov 8, 2002
    39
    Houston
    Accurately check vacuum advance with a dial back advance timing light. Jegs has the best price I've seen so far on one. To guesstimate, hook up the vac hose and see where the mark moves. Factors are whether you have manifold vac or ported. Some cannisters (most) have 20-22 degrees while others provide 10-12.
    You could also be due for some carb maintenance. Blown power piston or bad accelerator pump.
  9. reddog64
    Nov 9, 2000
    3,325
    hmmm...
    I'm gonna pull the carb apart and see if anythign is hanging around in it....
    It idles and revs in neutral awsome.. but not in gear.. it just dies off.... or chokes on deacceleration...
    ??? /forums/images/graemlins/1zhelp.gif
  10. tRustyK5
    Jul 23, 2000
    36,188
    1,396
    E-town baby!
    Try advancing your timing a bit. If drivability improves but no pinging advance it more. When you get a little pinging under partial throttle back it off a hair. That is the sweet spot.
    With the timing too retarded it will idle and rev fine because there isn't any load. When the timing is bang on it should barely drop in idle speed between nuetral and drive.
    rene
  11. reddog64
    Nov 9, 2000
    3,325
    Thanks Rene, I'll go try that...
    I'm starting to get frustrated with it...
    And want to play with my welder dangit!!!
    No one that sells gas is open on a sunday!!!
  12. reddog64
    Nov 9, 2000
    3,325
    hey Rene....
    That was it...
    Much better...
    Still Needs to be dialed in though... /forums/images/graemlins/eek.gif
  13. tRustyK5
    Jul 23, 2000
    36,188
    1,396
    E-town baby!
    Keep playing with it...as soon as it pings a little back it off a hair.
    Rene
  14. reddog64
    Nov 9, 2000
    3,325
    which way is it you turn it to make it run too hot... I know there's a certain way to turn (adv or retrd) that it will run hot, temp wise.... not that I want it to but I want to avoid it...
  15. tRustyK5
    Jul 23, 2000
    36,188
    1,396
    E-town baby!
    Usually too retarded will run hot because the exhaust is opening as the mixture is still firing...mostl it'll just be a dog and backfire through the carb though. Too advanced and it'll crank hard when starting...
    Rene
  16. reddog64
    Nov 9, 2000
    3,325
    cool I'll remember that! /forums/images/graemlins/cool.gif
  17. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    Rene, or others
    Assuming carb settings and jetting is correct, what would cause it to "diesel" at shutoff? I'm assuming a retarded condition will do this as it causes exhaust valve temps to increase, but not sure. I just threw my motor back in on Sunday (after removing it to replace the x-member), and really didn't get a chance to adjust the timing (no mark on balancer and no timing tab..... /forums/images/graemlins/confused.gif). I noticed that it will diesel after a good run and shutoff. It did not do it before, and I did not touch anything else, so I am assuming that I put the distributor back in a few degrees off. Any thoughts?
