Timing marks on 350 TBI?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 90K5, Jun 12, 2002.
  1. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Where is the timing gauge thing that you lie up the mark o nthe balancer to?
  2. Burbinator
    Burbinator 1/2 ton status
    Sep 14, 2001
    898
    Tempe, Arizona
    As you stand in front of the truck, it should be at the one o'clock position at the balancer. Should be fairly obvious if it's not missing or covered in gunk...
  3. chvyhs
    chvyhs 1/2 ton status
    Feb 12, 2001
    1,469
    Murrieta, California
    It's on the timing chain cover. If you don't see it from the top look for it from the bottom just to make sure it's still there. On my 90 Sub it's kind of hard to see but it's down there.
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    I've seen some late model rigs that just have what looks like a small steel tube for a timing tab. When the timing mark is centered in the hole, then the timing is set correctly. I guess it's just one more way to try to make us leave stuff stock... /forums/images/icons/shocked.gif
