Timing on a 350?
Discussion in 'The Garage' started by OrangeCrushK10, Jan 20, 2005.
  1. OrangeCrushK10
    OrangeCrushK10 1/2 ton status
    Jan 25, 2003
    1,425
    Square State + Suspension Item
    What degree advance should I run on a stock 350?
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    factory spec is 6 degree BTDC
  3. OrangeCrushK10
    Jan 25, 2003
    1,425
  4. dirtwarrior17
    dirtwarrior17 Banned
    May 14, 2004
    1,820
    Redding, CA
    While you have a gun you might want to find your optimum timing point. Mine is at 4 degrees but it's not stock. Each motor will run better at a certain point. Factory specs are good to have but i bet you will pick up a couple more if you run it a little closer to 0. Just make sure it doesn't want to knock.
  5. gmchevy
    gmchevy Registered Member
    Apr 14, 2004
    28
    North Carolina & Colorado
    I am from ft collins and i have always set my 350s up between 8 and 12 btdc due to the elevation.
  6. 3 on the tree
    3 on the tree 1/2 ton status
    Oct 16, 2004
    3,970
    gunnison colorado
    I am at 8000 ft and all my rigs are dialed up to 20 before. If I go down to the lowlands, I just dial it back down.
  7. 70jimmy
    70jimmy 3/4 ton status Premium Member GMOTM Winner
    Mar 3, 2000
    5,951
    247
    Released from Pueblo, told I belong in Southpark
    I have been told start with factory then add 1 degree for every 2000 feet in elevation. anybody else heard that. When I lived near the springs I was around 12 degrees.
  8. dirtwarrior17
    May 14, 2004
    1,820
    Redding, CA
    I think that is only for carbed engines. :confused:
  9. gmchevy
    Apr 14, 2004
    28
    thats what hes got
  10. gmchevy
    Apr 14, 2004
    28
    my old man always told me that so I know its right:)
  11. ssls6
    ssls6 Registered Member
    Jan 5, 2005
    86
    Dallas, TX
    That's a new one on me. I know when your lean detonation occurs with less advance. I always time for total timing (34-36 degrees) and try to get it in by 2800-3000 rpms. I usually run the vacuum advance off of "non-ported" vacuum.
