Timing Problem
Discussion in 'The Garage' started by k5blazerguy, Sep 2, 2003.
  1. k5blazerguy
    k5blazerguy Registered Member
    Oct 11, 2002
    53
    Ruidoso NM
    i have never been able to get k5 on "time" does anyone know an easier way to set the timing on my 85k5 without having to guess where the mark is /forums/images/graemlins/1zhelp.gif
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    umm look at the timing tab with a timing light?
  3. k5blazerguy
    Oct 11, 2002
    53
    Ruidoso NM
    i've done that and put the mark all over the tab. where the mark is now is about an inch off to the left of the tab and it runs a little better but still is not right
  4. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    umm look for the real big V. Then put it at like the second peak to the left of it. Should be about 4 degrees advanced if I'm thinking right. Thats a safe place to start. if your not running there, there may be more issues than just setting timing(being 180 out or cam improperly degreed).
  5. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    Does that one have the computer controlled advance where you need to disconnect the brown wire first before setting initial to Zero ??
  6. k5blazerguy
    Oct 11, 2002
    53
    Ruidoso NM
    i don't think that it is computer controlled. its an 85k5 and the motor is a 79,but i still have the hei dist. in it from the 85 motor
  7. MOABDADC22
    MOABDADC22 1/2 ton status
    Jul 24, 2001
    1,348
    Cheyenne, Wy
    Are you pulling and capping the vacuum advance?
