Timing questions
Discussion in 'The Garage' started by Hossbaby50, Jan 27, 2003.
  1. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I have some timing questions here. I just moved to Colorado. My trucks emission sticker says 4* BTDC. I had it set there in AZ and on the way to CO. I was told by some people that my timing up here should be 8-10* but they didn't say BTDC or after. So the other day I adjusted it to about 9* BTDC and my truck seems to run better now. So going from 4*-9* BTDC means I retarded my timing 5* correct. Or thats what I gather from reading another post here. I was under the impression that you should run the most advance possible which is closer to TDC. Is this correct? So why does my truck seem to have more power with less timing? As you might gather I am a bit confused on the whole subject. Thanks
    Harley
  2. chevyracing
    chevyracing 1/2 ton status
    Sep 8, 2001
    2,589
    Colorado
    You advanced your timing. I run mine at 8 BTDC and it runs great. BTDC means before top dead center. So the larger the number you go BTDC the more you advanced your timing.
    John
  3. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    The air is thinner up there
  4. MJB774X
    MJB774X 1/2 ton status
    Sep 26, 2002
    574
    SO CAL
    if you don't care about smog crap I advance my timing as much as possible without it pinging, before top dead center is when the mark on the damper shows on the top side of the o mark on the timing tab, trust me though your engine won't run if it is after top dead center so you must be in the right direction, I would put it at 8 or 10 though, advancing it as much as I do can hurt you engine if you don't know or understand well at what you are doing, for some reason to I find it better to time your ignition with the vacume advanced hooked up, also if your engine has a hard time cranking over your to advanced /forums/images/graemlins/usaflag.gif
  5. 70jimmy
    70jimmy 3/4 ton status Premium Member GMOTM Winner
    Mar 3, 2000
    5,962
    252
    Released from Pueblo, told I belong in Southpark
    I have been told that the stickers and books on the vehicles are for sea level. Advance 1 degree for every 2,000 feet in elevation over sea level. fort Collins is like 4900 feet. That would put you at 6 1/2. I like the others here have had good luck with 8 degrees up to about 8000 feet.
  6. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    ok, cool. Another poster on another post said that the more left on the damper the more retard on the timing. This is what confused me. Thanks alot. I did set my timing with the vacuum line hooked up. I forgot to disconnect it. Last time I timed the motor in PHX I tried setting it with the vacuum on and off and I didn't see a change in the time on the damper. Thanks again
    Harley
  7. MJB774X
    Sep 26, 2002
    574
    SO CAL
    never heard that, sounds like a good rule to go off of, especially when I go to the river with a boat or anywhere in anything for that matter /forums/images/graemlins/thumb.gif /forums/images/graemlins/usaflag.gif
  8. MEPR
    MEPR 1/2 ton status
    Oct 21, 2002
    1,546
    McChord AFB
    advance it till it pings then back it off a bit, climb some big hills and if it pings retard it. /forums/images/graemlins/thumb.gif 9-10* sounds about right.
