timing spec on OLD 350 ??
Discussion in 'The Garage' started by uglychevyZZ4, Feb 24, 2007.
  1. uglychevyZZ4
    uglychevyZZ4 3/4 ton status
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    i am trying to find a spec range for the 350's that had the timing tab that you have to see at the top of the timing cover, viewing from behind the water pump.. no idea of the year, its not mine and in a FJ40..
    if you have this style what year is yours? that should help..
  2. trailblazr81
    trailblazr81 1/2 ton status
    May 27, 2005
    931
    Hollister, CA
    Sounds like a 80's smogger motor. Id look at 4-8 BTDC. Or just advance it till you get pinging under load them back off a couple degree's.
  3. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Doesn't matter where the timing tab is, but if it is just a carbed engine set it somewhere between 4*-8* and go from there. BTW, most of the engines i've seen with the timing tab behind the water pump were 305 engines.
  4. trailblazr81
    May 27, 2005
    931
    Hollister, CA
    Ya my 86 K5 had a POS 305 and it was a pain trying to time with tab behind water pump.
